*Beep* 0 oil pressure
Old Jun 14, 2005 | 03:00 PM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
Hello,
I have a 88 GTA, 305 TPI with a digital dash... When it's hot outside and that I've been driving in the city for a while, I can hear a beep from the dash and see that my oil pressure is in the red. The engine seem to run no different than normal when it do this. It seem to only do that at a stop (when I'm waiting on a light).
Hope it won't cost too much!
Thanks!
Old Jun 14, 2005 | 04:38 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I have to ask, but you are full on oil correct? If you are full to what the dipstick marks as full, then your sender needs to be replaced. They are respectively $12-$15 at the parts store and screw on with one plug for the gauges.
Old Jun 14, 2005 | 07:51 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Yes, the oil level is it full. So what is the name of this part exactly?
Old Jun 14, 2005 | 11:10 PM
Metalhead's Avatar
Car: 89 Trans AM GTA, 99 Olds Alero GLS
Engine: TPI 350 L98
Axle/Gears: Borg Warner 3.27
I have about the same prob but I was told it was main bearings. When I crank up it is like 35# or maybe 40# then when I drive around it starts to drop and then when I set at a light it goes down to allllllmost the red if not on it. When I go it picks up a little.
I have also had people tell me that car is supposed to be like that...it wasnt like that before though. It used to hold like 45# or more all of the time that I can remember. So I know that isnt true.
Old Jun 15, 2005 | 07:56 AM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
The exact name of the part I need is the oil pressure sensor right?
Old Jun 15, 2005 | 08:32 AM
He has a good point, how many miles on the engine?
Yes, if it is the sensor, the name will be oil pressure sensor. I would wait for more people to chime in before replacing to many parts, it's hard to troubleshoot over the internet.
Old Jun 15, 2005 | 11:10 AM
Larry's Avatar
Car: 86 Corvette
I always install a temporary mechanical gage to check the oil pressure first.
Old Jun 15, 2005 | 11:37 AM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Beside the oil pressure sensor, what could the problem be then? I will do the most cheap stuff first to see if it's better. Thanks!
Old Jun 17, 2005 | 12:28 AM
WhiteKnight's Avatar
Car: 88 GTA
Transmission: Manual
i have a gta and my sender is dead. the digital dash is so *** damn annoying BEEP BEEP BEEP
drives me insane
Old Jun 17, 2005 | 07:23 AM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Is the sender and the oil pressure sensor the same thing?
Old Jun 17, 2005 | 08:13 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally posted by WaOnFiRe.Beside the oil pressure sensor, what could the problem be then?
Quite a few things, WaOnFiRe. You've already checked you're oil level, now what about the gauge itself? It might be faulty. Are you hearing any metal to metal (cam bearings) contact when pressure drops down to 0-psi?
It might even be you're oil pump itself. The relief valve adjustment might be too tight, or the valve spring is weak. The pump gears/cover could be a little worn, or the pump body's cover might have come loose. The screen could very well be clogged with gummy oil...
Of course, there's always the main and rod bearings...
Hope this helps you....
Old Jun 17, 2005 | 11:42 AM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
I don't here any metal to metal noise when it goes in the red...
So, Is the sender and the oil pressure sensor the same thing?
Old Jun 18, 2005 | 10:14 AM
1320 Right Ln.'s Avatar
yep, same thing, just different terminology. Usually, measuring devices which send their signal to the ecm are reffered to as sensors, while a device which sends it's signal straight to a gauge is usually called a sender. I'm not sure if this is the correct way to differenciate the two, but it's what i noticed:
to the ecm:
VSS
TPS
CTS
O2 - all these are called sensors
to gauges:
oil pressure sender
trans temp sender
etc.
Old Jun 18, 2005 | 11:48 AM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
The exact name is oil sending unit.
Old Jun 19, 2005 | 10:36 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
drives me insane
Feel free to yank it out and sell it to me. I'll even include a 140mph standard GTA dash.
-- Joe
Old Jun 19, 2005 | 11:21 AM
Car: 88 GTA
-- Joe
No, its ok, once I get the sender replaced, I'll like my digital dash. Trying to take the thing apart to change one of the dash lights is a horrible task as well with digital.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
