Dynoed new motor combo
Old Jul 7, 2005 | 06:27 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
383 TF Heads 219 cam , Edelbrock base asm runners and stock 48mm TB.
275HPand 391 TQ. This was on a basic tune.
Old Jul 7, 2005 | 11:42 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Are you still using the stock prom? what was the Air/fuel ratio like?
Old Jul 8, 2005 | 12:54 AM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Post a chart, and where did the power peaks occur?? Where was over 350 ft/lbs held to and from?
Old Jul 8, 2005 | 09:20 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I'll see if I can get a scanner or something, but peak power was 4600 RPM and the torque was from 3300 through- 4100. All the runs were from 3K and up.
AF Ratio was 13.7 (3400-3800) 3900 was 12.8 4000 was 11.8 and it was down hill from there. Next time were going to try to lean up the upper end and see what happens. We were accually having a hard time doing it i the chip. We were taking a TON of fuel away and it was still shoing 10 on the AF by 4500 all through 6K.
Old Jul 8, 2005 | 09:22 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
We are using a VERY lighly modified prom until we figure out why we cant take fuel away at upper rpms. Only change was the constant for the LS1 injectors and the fans and of couse trying to pull fuel out.
Accually www.LSRacingchips.com was doing it for me. Hes a friend of mine so maybe my graph is up there somewhere. I'll have to ask if he has the origional run. the first one run was the best. By the time 8 runs was done and my temp was way past 220 we were only getting 260ish/370
Old Jul 9, 2005 | 04:16 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Was this your combo? I thought you had a superram?
Old Jul 14, 2005 | 04:21 PM
st5150's Avatar
Engine: 302
Something is wrong. You definately have a mismatch in your combo. You should be making at least 50rwhp more with a well matched combo given 383 cubes.
Old Jul 14, 2005 | 04:31 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Well I am running -5* base timing because anything advanced more then that and I get major valve chatter. Not pinging. You can accually hear the valves, but if its retarded that much it doesnt do it.
Old Jul 14, 2005 | 07:28 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Holy smokes...no wonder you didn't make any power! I'm a little fuzzy on your "valve clatter" statement.
Old Jul 15, 2005 | 11:31 AM
Damon's Avatar
Yeah, that don't sound right to me either. Something's screwy.
Old Jul 15, 2005 | 11:38 AM
JADIII35's Avatar
Car: 1991 trans am
Engine: 383
Matt,
Nice, very nice!!! Glad to see things are moving along for you. I would always offer my assistance, but you are much more knowledgeable than I. I'm sure you guys will work out the "bugs" and reach you full potential.
Jim
Old Jul 15, 2005 | 01:14 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Were going to work on the valve chatter next week and hope to fix that problem. I would like to get 300 RWHP and hit the 400 TQ.
Old Jul 15, 2005 | 05:35 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
did you port out that edelbrock manifold? i bet if you opened them up you would gain 10rwhp right there and probly more
other than that... your combo looks good for easy 300rwhp. hope you get that chatter fixed up and advance that timing some.
i think 320rwp isnt out of the question
Old Jul 15, 2005 | 05:48 PM
wackytower's Avatar
Car: 1985 Trans Am
Engine: Superramed 406
Axle/Gears: 10 bolt 3:73
Copy cat
Old Jul 15, 2005 | 06:47 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Its all opened up big time.
Old Jul 15, 2005 | 07:08 PM
wackytower's Avatar
Car: 1985 Trans Am
whats that mean?
1992rs/ss
Jan 31, 2025 05:10 PM
MustangBeater20
Oct 29, 2022 09:20 PM
1984HO
Mar 19, 2021 11:59 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reborn756
Sep 4, 2015 03:42 AM
