What is this plug for
Old Jul 11, 2005 | 06:17 PM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
This is the only plug I can't seem to find a home for.
Old Jul 11, 2005 | 06:44 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Looks like the fan plug...you have dual fans? If so, follow the harness back from them.
Old Jul 11, 2005 | 06:48 PM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
I had the idea it was a fan plug. I'm running a seperate fan switch so I can get rid of this I guess.
Thanks,
Matt
I have a single fan. The car WAS a 305 carb now it's a 350 TPI.
Old Jul 12, 2005 | 10:55 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
Why would a fan have six wires?
It looks like the plug for the electronic spark control (ESC), which is located on the firewall near the power brake booster and other assorted relays.
Old Jul 12, 2005 | 12:36 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Dual fan connectors have a 6 way plug, I'll pop my hood on my '89 later to verify...also, I don't think that connector would reach to the brake booster...looks like it's on the pass-side up front
Old Jul 12, 2005 | 01:39 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
Hmm, I didn't know that about the dual-fan systems... do they use a third wire for speed/duty cycle control?
Yeah, I noticed that it was on the passenger side too, but the only time I've ever seen that connector on my '86 was for the ESC module. If I recall correctly, dual fans weren't an option until 1988, and vwaltdog has an '87 according to his profile. Maybe a previous owner thought it would be a good idea to "relocate" some of the wiring devices .
Hope you figure it out, vwaltdog.
Old Jul 12, 2005 | 01:43 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
He saud hes running a 350 TPI, perhaps hes running an 88-92 harness in the car now?
Old Jul 12, 2005 | 09:23 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I think it goes to the MAF sensor.
I just checked my car. It is not the MAF sensor.
All I know is that the male and female connectrs like that one in the pic are located on the diver side of the battery. My one fan is out now, maybe soon I can trace the wires.
Old Jul 12, 2005 | 11:17 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The plug is for dual fans.
Not sure why a plug was needed for adding a little extra usless wiring but, this is a GM product we're talking about.
Old Jul 13, 2005 | 09:22 AM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
Car: 87 Trans Am
Engine: 87-92?? 350
89 TPI (no 9th injector)
88 tpi wiring harness
I have the plug rerouted to the passenger side so I can reach the battery for the ecm wire. The ESC is plugged in already.
Old Jul 13, 2005 | 09:42 AM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
GM used a plug so they could utilize different fan setups without having to change the entire wiring harness. Thankfully, for anyone wanting to convert a setup to multiple fans, etc.
You should be able to use that plug for your setup, I'm assuming you'll be running the requisite relays and everything, if you've got that, and it's intact with the 12V leads with fusible links, most of your fan wiring is done already. I can see one of the relays hanging there.
Only problem is, that is the only 6 prong weatherpack used on these cars, and it's not too common, if you don't have the other half. I went and bought a "male/female" (tower/socket?) 6 prong and just repinned the wires into the new conenctors, since the stock connector is keyed.
Old Jul 14, 2005 | 09:31 AM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
I actually put a separate relay and low temperature switch fan kit.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
