E Z way to I D a 305 or 350?
Old Aug 3, 2005 | 07:58 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
A buddy of mine has deceided he want s thirdgen. He wants a 91/92 so it will have the speed density intake. Question is:
Is there an E Z way to tell just by looking--without getting the block casting numbers. or without running a check on the VIN-- whether it's a 305 or 350?
I know on my 89 the engine code in the VIN is 8 (I think anyway), but he was a out looking at one and the guy kept telling him it was a 350, even though the ad the guy ran said 305, and when my buddy first showed up the guy said it was 305. Need less to say he did not trust him as far as what he was being told about whether it was a 305 or 350.
Old Aug 3, 2005 | 11:19 AM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
e is for tbi 305 and f is for the tpi 305
If it has a 5 speed its a 305 they didnt come with a 350. I also think in thoughs years the 350 didnt have t-top but not positive on that. They also had the sd on the 90 cars.
Old Aug 3, 2005 | 11:29 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
I'm assuming that is a "typo"
The f for 350?
Are U talking about the VIN?
Old Aug 3, 2005 | 11:54 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
NO. the 8th digit of the VIN is the engine code
E = TBI 305
F = TPI 305
8 = TPI 350
Old Aug 3, 2005 | 11:59 AM
SkullLeader's Avatar
Car: '87 Iroc Z
Engine: TPI 305
Transmission: Manual
Old Aug 3, 2005 | 01:22 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
OOOOOPS......I misread your post. Sometimes I need a good swift kick in the butt and a wake up call!!!
SORRY!!!
Thanks for the clearification and my education
Appreciate the information. I will pass it along to my soon to be a thirdgenner buddy!
By the way, he is geting rid of a 4th gen (95 I think) just because he is tired of being one of the sheep where everybody had the same and just wants to be different, and likes doing restoration type projects. If I know him, in a couple years, he will have a thirdgen as nice as ANYBODY on this board. He paints cars for a living and has built several winning race cars (circle track) in the past. Now if I can just talk hm into the free paint job (yeah right) we talked about during a recent beer chugging session.
Again Thanks!
Old Aug 3, 2005 | 01:55 PM
rock'n z's Avatar
Car: 88 camaro iroc
Engine: 5.7 tuned port
Transmission: 700 r4
a quick easy and good sure way to tell if u have a 305 0r 350 look on the back of the block on the pass side down where the tranny bolts to the engine there will be a stamp on the block that says 5.0 or 5.7 it is the only sure way to tell but ull need a flash light to see it look straight down and ull see it
Old Aug 3, 2005 | 05:12 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Is there a pic of an engine out of the car with that stamp? I tried looking, but I still don't know what I'm looking for.
Old Aug 3, 2005 | 05:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Not all blocks have the actual displacement shown, but you can look in the same place for the casting numbers and then look up the bore size.
Old Aug 3, 2005 | 05:32 PM
rock'n z's Avatar
Car: 88 camaro iroc
actully all oem blocks and gm crate engines have that stamped on the engine block my friend who works at gm told me to identify my block that way anf so far all blocks i have seen have had that on them
Old Aug 4, 2005 | 03:55 AM
Silver_Panther's Avatar
Car: 1982 Z28 & 1987 Z28
Engine: Carbed 400ci & TPI 305ci
Transmission: TH-200C & TH-700R4
Isn't the 305 Oil dipstick on the passenger side and the 350 dipstick on the driver side?
Old Aug 4, 2005 | 12:43 PM
Car: 1994 Trans Am
The dipstick is on the passenger side for both motors.
Old Aug 4, 2005 | 12:46 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The markings aren't stamped, they're cast in, and there are far more blocks that don't have it than do. Only the later blocks have it.
<img src="http://www.mortec.com/cast14.gif">
Old Aug 4, 2005 | 12:47 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Dipstick location has nothing to do with displacement.
Old Aug 4, 2005 | 12:50 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
I hope not, cause my dipstick is on the passenger side and it's "supposed" to be a 350. If not, I've got one of the best running 305's in the country!!!
One thing I have noticed, is that in the mid 80's production years, the alternator seems to be on the passenger side on the 305's, and on the drivers side on the 350's, but I'm not sure that is always 100% the case either. Maybe just the ones I have actually looked at. Regardless of if's that's true or not, I know many were done that way--WONDER WHY?
Old Aug 4, 2005 | 01:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A 305 will have the same accessory mounting as a 350 of the same year in the same application.
The only way to tell the bore of the block is to take it apart and measure it, or to check the casting numbers.
Old Aug 4, 2005 | 08:41 PM
SGT.ROCK's Avatar
Car: 1989 Trans Am
Transmission: 700R
Axle/Gears: 9 bolt 2.77
UM
Doesnt the tach go orange color at 5000 rpm then red at 5500 rpm on a 350 car and the 305 turn orange at 5500 and go red at 6000? Just wondered
Old Aug 4, 2005 | 09:25 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Different engine options had different tachs in different years. Checking the VIN would be more definitive, but you can't always be sure the engine hasn't been changed.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
