TPI Boggs down when make sharp turn
Old Aug 20, 2005 | 10:06 PM
rockinfirebird's Avatar
Car: 1988 GTA T/a
Hey guys....yeah my GTA boggs down when i turn really sharp....idk what the problem is. Also, when i turn the car off there is a humming noise coming from the back of the car....fuel pump maybe???. Umm one more thing, at low rpm's it's been missing lately, but like...if i keep the rpm's up, it does fine. IS ALL THIS CONNECTED???? ok well if anyone can help me, i'd appreciate it...thanks
Old Aug 20, 2005 | 11:08 PM
rcwest32's Avatar
Yup, fuel pump time, IMO.
Old Aug 20, 2005 | 11:18 PM
Guest
Guest
Posts: n/a
Sounds more like low fuel level to me.
Old Aug 20, 2005 | 11:19 PM
TragicPark's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L V8 TPI
My GTA likes to die or bog down when I turn right with a low tank of gas. No humming however...
~Roger
Old Aug 21, 2005 | 03:50 PM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Re: TPI Boggs down when make sharp turn
I had the same problem. I replaced the gas tank vent valve which is where the humming was coming from. I haven't had any problems since then. When that valve stops venting the gas tank the pressure in the tank increases to the point where your fuel pump cuts out. It happens mainly on hot days.
Old Aug 21, 2005 | 06:02 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
My vette does it too.
Old Aug 21, 2005 | 08:08 PM
3leggedog's Avatar
From: It's a west coast thing, you may not understand?
Car: 88 IROC, tpi, t top,
Engine: LB9
Transmission: 5 speed
On mine it means its time to get gas, agin!! Gas tank pressure? Do you mean vacume? never had pressure, only vacume when this happens. Just opening the fill cap, on hot day would test your vent. I never ever want pressure in my tank.
Old Aug 21, 2005 | 08:13 PM
onebluemcm's Avatar
From: Ithaca, NY - 10 sq mi surrounded by reality - I'm SOL!
Car: '89 IROC-Z
Engine: 305 TPI in stock trim
Transmission: T-5 w/ Hurst B/P shifter
My IROC will sputter during sharp turns with low fuel levels and the humming can be normal fuel pump activity - mine does it as well. If the stalling/sputtering happens without a low fuel level, then there may be a different problem.
K
Old Aug 22, 2005 | 05:36 AM
pwdbychevy's Avatar
Yeah that's what I meant
Old Aug 22, 2005 | 08:09 AM
305TA85's Avatar
Car: 85 T/A & 98 T/A
Engine: 305 tpi/ 5.7 LS1
Transmission: 700 r4/ T-56
Axle/Gears: 3.23/ 3.42
mine did it around turns on a low tank. put a new feul pump in no more problem. i can now drive with an extra gallon and a half before fueling.
Old Aug 22, 2005 | 09:40 AM
8UpAFord's Avatar
Car: 1988 Corvette
So is this happening because the fuel sending unit is a little to short and not catching enough fuel, i'm guessing only fix is a fuel sending unit? When i have 3 gallons or more in my car it runs prefect but anything under I feel eirther a total preformance loss or a little hesitation(only on WOT)..
Funny thing is I raced my friends 2001 convertibale cobra like like a year ago and it happend i wanted less gas for ligher weight. i still worked him old school. that was when my 88 vette was stock and only mod was a 180 thermostat.
Old Aug 23, 2005 | 09:48 AM
305TA85's Avatar
NO ITS HAPPENING BECAUSE THE PUMP IS BAD. FACTORY PUT THE SENDING UNIT WHERE IT SHOULD BE. THE PUMP DOESN'T TURN ENOUGH TO COMPENSATE ENOUGH FUEL PICKUP WHEN IT SPLASHES AROUND AND GETS AIR POCKETS. NEW PUMP WILL FIX THE PROBLEM.
Old Aug 23, 2005 | 11:59 AM
8UpAFord's Avatar
Car: 1988 Corvette
oh damn that sucks, so i need a new pump soon. Should i just buy a pump or the entire unit? Also anyone recommand a certian brand. i'm putting a stroker motor in it sooner rather then later, what would be a good PSI and what brand too?
thanks
Old Aug 23, 2005 | 12:09 PM
305TA85's Avatar
I don't know about a vette probably the same but 85-92 f-bodies have in tank pumps. Anyone correct me if im wrong, but no sending units just drop the tank, take of the top lock thing, and replace the pump, put it all back in
Old Aug 23, 2005 | 06:38 PM
Guest
Guest
Posts: n/a
Every TPI car does it, even ones brand new off the showroom floor. Has something to do with the pickup being in the middle of the tank and what fuel is left being all over to the side.
Old Aug 25, 2005 | 07:03 AM
305TA85's Avatar
mine stoped with a new pump, and can now suck the tank dry.
Old Aug 25, 2005 | 09:53 AM
Guest
Guest
Posts: n/a
Go drain the tank, put a gallon in, and take a corner at .9g and tell me it doesnt bog.
The strainer is located in the center of the tank, if the fuel moves to the side (and it will) there is no fuel for the engine. The baffled tanks are only minimally better.
Old Aug 25, 2005 | 10:01 AM
rcwest32's Avatar
thanks
I've always liked the Walbro pumps. As far as what psi, just get an AFPR and experiment. I'd start at 50 psi if you're using stock 350 injectors.
86IROC112
Aug 17, 2015 02:00 PM
novaderrik
Aug 10, 2015 12:44 PM
Fronzizzle
Aug 9, 2015 01:15 PM
BrianI
Aug 9, 2015 11:52 AM
