ZZ4 Camshaft w/stock heads?
Old Aug 24, 2005 | 07:57 AM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
can a ZZ4 Camshaft be installed in a L98 with stock heads w/o problems?
If not what needs to take place so that they will?
here's what I bought:
3. ZZ4 roller cam 7500 miles exc cond, will throw in ZZ4 take out springs, lightweight retainers, and some cheap Proform stamped roller tip rockers in 1.5 ratio. $75 **SOLD
Old Aug 24, 2005 | 08:45 AM
Chrome's Avatar
Car: 92' RS Camaro
Probably have to have the guides milled and put threaded studs in.
Some people gotten away without doing that, but one in particular I know pulled a stud after a couple thousand miles on it.
Do a quick search. Might be a time to Port your heads or upgrade...
Old Aug 24, 2005 | 08:49 AM
Car: '87 Iroc-Z
that's what I'm trying to avoid doing, I get some Worlds S/R Torquer heads at the end of september.
I just wanna put this one in so I wont get beat so much on friday and saturday nights.I took my new 3 week old iroc out last weekend and eclipses smoked me
Old Aug 26, 2005 | 08:41 PM
sinister12c's Avatar
Car: 1989 Iroc-z
Engine: 5.7 TPI w/ZZ3 H.O. camshaft and alot of other enigine mods.
ZZ4 cam
what did the ZZ4 cam come out of, for the third gen's L98 there's a ZZ3 cam made by GM performance parts, and the ZZ9 cam made by TPI's. If you buy the ZZ3, or the ZZ9 cam it's a direct install, they are roller camshafts, nothing else will need changed, i do recommend the roller rockers, they can free up some horsepower, so you know i installed the ZZ3 cam it has a slight lope to it, sounds great with other mods, the ZZ9 is better, but i was in a big hurry to get mine running. here's the Gm P/N for the ZZ3 H.O. roller cam #10185071 the specs are duration 208 intake 221 exhaust at .050 lift, and a .474 intake and .501 exhaust lift, it my local GM dealer two days to get it. cost is about $240
Old Aug 27, 2005 | 12:30 AM
87350IROC's Avatar
Car: 87' IROC
Please install screw in rocker studs with the ZZ4 cam. My engine was the one that pulled 2 stock pressed in studs in about 1000-1500 miles. This led to damage to the pushrods, rockers, and pushrod slots in the heads. I now run screw in studs, guide plates, and hardened pushrods. Still on the L98 heads. So save yourself $300 or so in repairs and do it right the first time.
Sinister, the ZZ4 cam is the same as the ZZ3.
Old Aug 27, 2005 | 07:20 AM
Car: '87 Iroc-Z
so put those studs in along with cutting the guides and with those springs and roller rockers, I should be fine?
Old Aug 27, 2005 | 01:40 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
should be fine after that . I am loveing my ZZ4 camshaft . Nice little lope to it and the ECM dealt with mine fine
Old Aug 27, 2005 | 02:29 PM
Car: '87 Iroc-Z
right on bro! I'm going for it! I got a sweet deal on a ZZ4 cam w/extras
Old Aug 27, 2005 | 03:32 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Maybe the Eclipse you raced was a decently fast one ??
It's all to common nowadays for somebody to trick out
an Import .. you never really know what they have under
the hood ..untill its too late
Old Aug 30, 2005 | 02:45 AM
Blackbari's Avatar
Car: 1988 IROC
Engine: B2L
Transmission: MD8
Axle/Gears: 2.77 9 Bolt
Need Chip or Stock Chip OK?
Can the stock chip be used with the ZZ3 cam on a MAF TPI?
Old Sep 1, 2005 | 11:52 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Re: Need Chip or Stock Chip OK?
yup . It won't be perfect but mine fired right up. Heck I was running a 305 prom in it from the stock motor ....and it still fired right up :-) Even though it was a 350 . The Maf cars seem forgiveing even with a mild cam swap .
Old Mar 30, 2009 | 12:14 AM
87transGTA's Avatar
Car: 87 GTA
Engine: 350 Tune port
Transmission: 700r4,2500 stall
Re: ZZ4 Camshaft w/stock heads?
would it be possible to put in threaded studs in without pulling the heads off?
Old Mar 31, 2009 | 10:31 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
i don't think so
Old Mar 31, 2009 | 11:36 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Axle/Gears: G80,10 bolt 3.42's
Prolly need to upgrade the springs while you got the heads off.ZZ4 cam has .480/.510 lift.Thats alot more than the stock cam and more than the stock springs are designed to handle.
just re read your first post.Forgot you said you were doing the springs.
Old Mar 31, 2009 | 11:44 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
is everyone getting the zz4 cams. i just got one with about 2k miles on it and got the push rods springs, not rockers. i have to get full roller 1.6 rockers and looks like i will need screw in studs too. and new valve covers.
im going the other way though - 601 heads which will get me a little more compression on a 305.
just want a lil more speed but still street legal. also have tpi and hooker 2055's but im not sure about the cat back exhaust keep changing my mind.
Old Apr 16, 2009 | 07:04 AM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
would you have to use the screw in studs w/ aftermarket heads?
Old Apr 16, 2009 | 07:46 AM
zipfast's Avatar
Car: 94 9c1 Caprice
Engine: LT1 (3-fity)
Transmission: 4L60E reBUILT
Axle/Gears: 3:08 POSI (out)
Which aftermarket heads?
If you have them you can check.
Or check online for the head specs.
Old Apr 16, 2009 | 10:14 AM
87350IROC's Avatar
Car: 87' IROC
Most quality aftermarket heads already have screw in studs.
Old Apr 16, 2009 | 11:06 AM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
i was thinking of using edelbrock performers.
Old Apr 16, 2009 | 12:02 PM
CBR1000RR's Avatar
Car: 91 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 10 bolt 3.73's
I'm running the stock L98 heads with press in rocker studs and a ZZ4 cam. The heads are set up to run the .510 exhaust lift. Have about 6,000 miles on it. No problems yet. I would recommend having screw in rocker studs if you are running any valve spring that's stiffer then stock.
Old Apr 16, 2009 | 01:02 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
I have a l03 305 im converting to a TPI 305 motor, (no i am not buying a 350) can I use that zz3 cam? my cost is 225.50, (i was probably going to keep the L03 heads) if not, anyone have recommendations on a cam for the l03 heads?
Old Apr 18, 2009 | 12:16 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
You can use the stock head but you would need to change the heads to screw in studs and use guideplates. The zz4 cam is probably a bit too much for the stock heads.
You coud go with a used LT1 cam (about $30) and add some new springs, locks and retainers. You can use the zz4 springs, lock and retainers and buy them all from GMpartsdirect.com for under $100.
Old Apr 18, 2009 | 10:54 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Those heads were "set-up" by trimming the lower edge of the valve locks (for clearance to valve guide) and by installing valve springs from the ZZ3 motor. I also ran them for years of spirited driving.
Bill
Old Apr 18, 2009 | 12:00 PM
CBR1000RR's Avatar
Car: 91 Z28
Engine: 355
Bill
Whats up Bill? Your heads worked out great. Motor runs good. Still needs a tune though. Going to a mini ram soon.
Old May 14, 2011 | 10:26 PM
druck's Avatar
I have a 89 Firebird GTA trans Am and put a zz4 cam in it. Also put 24lb. injectors in it from the stock 22lb. I was told by a performance engine builder to set the timing at stock. I do believe it's 6 BTDC. The engine almost died. So I set it at 10 BTDC. It runs good but you can barly here it lobe. When the engine warms up it starts surging.
When driving it has a lot of power but when you hold the speed steady it spits and sputters really bad. If you give it gas it runs strong. Any body have any ideas wants wrong.
Old May 14, 2011 | 10:30 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
sounds like a vac leak.
Old May 14, 2011 | 11:18 PM
druck's Avatar
Ok I'll check it out. I'll let you know
lt500r55
Sep 1, 2021 01:30 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Ducati900ss
Sep 2, 2015 09:05 AM
z28guy134
Sep 1, 2015 11:50 PM
italiano67
Aug 31, 2015 06:04 PM
