No start situation ( sometimes (
Old Aug 29, 2005 | 01:39 PM
Uwe 1985-IROC's Avatar
Car: 1985 IROC-Z28
Engine: TPI 350
Transmission: TH700-R4
Hi guys,
I have a little problem with my car: Some history first : I swapped my original 305 engine for a 350 and my 870 computer for a 165 one. I changed my wiring and burned my own chip... and now my problem starts : I tried 2 different "bins", one $32B ( ABWT ) and one $6E ( APYU ). Iīm using Flash-EEPROMS ( AT29C256 ). I changed the "fan-on temperature" from 225 to 210 ( cause I have a 180 stat instead of the 195 stat ) and I delete the code "36" ( mass-burnoff-cycle ) and the "vats". Most of the time, my car starts fine and runs great, but from time to time I canīt get it started. It cranks fine, but no start. Seems like "vats enabled", donīt know if spark or fuel is missing. Right now, my car is sitting 10 miles away, cause I couldnīt get it run again. I tried to unplug my MAF and I tried to unplug my Ignition ( the plug for setting the base-ignition ). What could be the reasons for the random "no-start" situation ??? ( Donīt know, If this is the right forum, perhaps you should move it to the right one )
Thanks, Uwe
Old Aug 31, 2005 | 12:13 AM
Car: 1985 IROC-Z28
Engine: TPI 350
TTT...
Please, no ideas ??
Old Aug 31, 2005 | 12:41 AM
PROCHARGEDTA's Avatar
Car: 1989 PONTIAC FORMULA - 1992 PONTIAC TRANS AM
Engine: BOTH 5.7L 350
Transmission: BOTH 700-R4
NEED TO CHECK FOR SPARK AND FUEL PRESSER FIRST.I HAD THE SAME PROBLEM WITH MY 89 FORMULA AND I FOUND THE PROBLEM TO BE WAS THE ECM.IT WAS NOT READING THE SPARK REF.FROM THE DISTRIBUTER CAUSING NO SPARK.
Old Aug 31, 2005 | 11:45 AM
smnitWS6TA's Avatar
Car: 98 Z28
Engine: 346 LS1
Transmission: 6 spd.
Axle/Gears: Ford 9" 4.11
Is the fuel pump running? I had the same problem and it was my fuel pump relay going bad, I hotwired it for a day until I got a new one and then the little hard to find fuse blew. There's a fuse, looks like a plug with a cap on it, next to the battery, it was blown. Put a new relay and fuse in and no more problems. Just an easy thing to check. Need to check fuel and spark to.
Old Aug 31, 2005 | 07:35 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
In addition to the fuel pump relay, I would also replace the oil pressure switch.
Old Sep 5, 2005 | 02:47 PM
Car: 1985 IROC-Z28
Engine: TPI 350
Okay, no-start-situation today : I checked for spark ( with a timing light ) : No spark !!! - My fuelpump is okay, I hooked up a pressure-guage and it reads fine ( doesnīt mean that my injectors are firing ). After I disconnected my battery for an hour, I could start my car without problems. Could this be ECM-related or should I replace my ignition-module ? ( By the way, if I disconnect the 4-wire-connector between the distributor and the ECM, should I get spark or not ? )
Uwe
Old Oct 11, 2005 | 03:50 PM
Car: 1985 IROC-Z28
Engine: TPI 350
Still the same problem !!! - Today again no-start-situation ! - Normally my fuelpump primes for 2 seconds every time I turn ignition on. But now it doesnīt ( I have to wait exactly 12 seconds between ignition-on to hear the fuel-pump ). I have no spark and no fuel ( pressure-guage shows nothing). Hooked up another ECM with the old chip ... same result. With no chip installed the fuel-pump primes everytime I turn the key ( but still no start, perhaps this is okay with no chip inside ). I think tomorrow everything is allright again ( battery unhooked overnight ). The last modifications were the ECM-swap, wiring-change and a new distributor ( complete with coil and ignition-module ) - Iīm lost now, no ideas any more !
Uwe
Old Oct 11, 2005 | 04:48 PM
blander66's Avatar
Check your pick up coil i had a simlar problem on one of my cars and that is what caused it
Old Oct 12, 2005 | 12:53 PM
Car: 1985 IROC-Z28
Engine: TPI 350
No start this morning ( the battery was disconnected over night ). I did some testing and after I disconnected the tach-filter, wow, the car started !!! - Is this a common problem or was I just lucky ?
Uwe
jklein337
Sep 19, 2018 06:23 PM
chazman
Aug 28, 2018 03:25 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
soarestransam
Sep 1, 2015 04:00 PM
chazman
Aug 22, 2015 02:01 PM
