What is this on the bottom of my Throttle Body? PIC
Old Aug 30, 2005 | 10:47 PM
Project's Avatar
Car: 85 Camaro Z28
Transmission: 700-R4
I have this Lingenfelter Performance Engineering 58mm TB that I bought. On the back there is this thing that says
MPFI Rochester Products, Product Number is 17075921 and has a sensor in it, what exacty is it, what does it do...is it aftermarket? What do they cost? Call me an idiot but this isn't what is on my current TB.
Attached Thumbnails What is this on the bottom of my Throttle Body? PIC-tb5.jpg
Old Aug 30, 2005 | 10:54 PM
TPIgirl's Avatar
Car: 89 Irocz
Engine: 350TPI $6E
Idle Air Control Motor
Old Aug 30, 2005 | 10:57 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
It is where your coolant runs through the throttle body to heat up the TB, for those who live up north. And I also think your IAC(Idle Air Control) plugs in there. I bypassed my coolant from the TB, but kept my IAC plugged in.
Old Aug 30, 2005 | 11:07 PM
Doug Gulley's Avatar
Car: A Black One
Engine: 383 Chevy
Transmission: Retro T56... :>)
The housing and IAC "should" be on your old throttle body. It's a stock GM part that are on all TPI throttle bodies.
Old Aug 30, 2005 | 11:10 PM
Project's Avatar
Car: 85 Camaro Z28
So this is not an aftermarket product?
Really wierd, my old TB doesn't have this at all-
Thanks for the help
Old Aug 31, 2005 | 12:42 AM
Car: A Black One
Engine: 383 Chevy
Stock part. I just got one from a Chevy dealer just like it. Put it on tonight. I've seem them on www.tpiparts.com for $35.00. Not including the IAC motor.
Old Aug 31, 2005 | 11:10 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
How does your old throttle body not have one? If it's a TPI, it has to have one for everything to connect up and work (TB bypass excluded)
Old May 8, 2011 | 06:46 PM
11ellswray's Avatar
Car: 1986 Camaro Z28
Engine: 385" SBC
Transmission: built out 700r4
Axle/Gears: 4th gen, 373, LSD, GIRDLE
Re: What is this on the bottom of my Throttle Body? PIC
y did you bypass it? my guess is that a cooler tb is a better tb, did yoiu pick up any noticable gains or see any changes in driveability?
Old May 9, 2011 | 05:58 AM
Car: 89 Formula
Engine: 383 SBC/HSR
You won't notice any performance gains or losses, but I was removing all the clutter around my engine...a/c, air pump, canister, coolant lines, heater core, to make the engine easier to work on. My car is not a daily driver so some of the OEM components aren't necessary on a car built for the drag strip.
I just keep my fans on longer to cool my engine, so the coolant lines for the oil and TB weren't necessary.
Old Jul 7, 2011 | 07:35 AM
mcb55-210's Avatar
An old thread, but am looking for this same part. Typed in tpiparts.com, and it took me to turbo parts.........will try calling the phone number later. Any other known source for a replacement housing?
Old Jul 7, 2011 | 03:39 PM
mcb55-210's Avatar
Found tpiparts.com at tpiparts.net. Have one ordered.
Old Aug 3, 2011 | 11:37 PM
CAMAR0kid93's Avatar
Car: 1987 Chevrolet Camaro Iroc-z
Engine: 305 CID Tuned Port Injection
Axle/Gears: 3.23:1
the previous owner of my 87 Iroc bypassed the coolant from the throttle body. Are there any negative effects on the way the engine runs. Will there be problems in cold weather?
I really dont understand why he did it, and I'm thinking about just reconnecting it, but I dont know if its worth it.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
