Corvette L98 Alum. Heads EGR
Old Nov 29, 2005 | 11:49 AM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Ok how do I get EGR to work with the Vette L98 heads? In other words how did it work on the vette? Parts I need etc.
Old Nov 29, 2005 | 12:03 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
you need a corvette intake manifold OR buy an aftermarket one like Accel which put the corvette EGR boss in there.. 2nd you will need to get an EGR adapter kit to plumb into your headers. scoggin dicky makes one. their website is www.sdpc2000.com
Old Nov 29, 2005 | 01:08 PM
crrllmich's Avatar
Engine: L03, LS1
Thanks.
Will it trash my gas milage if I dont use EGR?
I know I have to disable it in the PROM.
Old Nov 29, 2005 | 04:27 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
it wont hurt gas mileage... i've actually heard it increases after the deletion
but it will increase your emissions
Old Nov 29, 2005 | 08:31 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
See my post at the bottom of this thread:
https://www.thirdgen.org/techbb2/sho...hreadid=331771
Old Dec 4, 2005 | 12:47 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
As far as gas mileage goes, deleting the EGR can hurt it.
When the EGR is no longer diluting the mixture with an inert gas, detonation can occur. Depends on a lot of variables.
IF detonation does occur, the ECM should back-off the ign timing, which will hurt your gas mileage.
Old Dec 4, 2005 | 03:03 PM
CC89Formula's Avatar
Car: 89 Formula
Engine: 5.7 TPI
when i took off the EGR it didnt hurt/help anything at all.
Old Dec 5, 2005 | 02:49 PM
92zcamaroperson's Avatar
Car: 92 z28 25th
Engine: 5.7 liter
Transmission: 700-R4
my car has an aftermarket base manifold. Its an edelbrock. Does it have the correct ports for the corvette egr plumming? Or do they make manifolds for camaros and then different ones for corvettes?
aside from that I want to get a set of these heads. The ones im looking at have been modified to accept a cam with up to 540 lift. How difficult will it be to tune my tpi set up with a cam that big as it is speed density and doesnt have a maf? Think it would run at all?
thanks
lt500r55
Sep 1, 2021 01:30 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
TreDeClaw
Aug 14, 2015 06:58 PM
drathaar907
Aug 6, 2015 04:20 PM
