Head Upgrade
Old Jan 15, 2006 | 12:02 AM
mantiz85ws6's Avatar
Car: 85 Trans Am
Engine: 350 T.P.I.
Transmission: WC T-5
Head Upgrade
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Will these work well with a tpi setup?? Looking to upgrade basically stock heads w/ a 3 angle valve job with these.
Old Jan 15, 2006 | 02:15 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
They should.
Hurry up before they run out of swimsuit calendars!
Old Jan 15, 2006 | 09:37 PM
Shagwell's Avatar
Car: projects.......
not bad for $400. -
Old Jan 19, 2006 | 09:53 PM
Car: 85 Trans Am
Engine: 350 T.P.I.
Anymore opinions or suggestions?? There are crap loads on e-bay and i'm a little confused. I am running 10:1 comp. 1.6 RR & an Isky 264 Mega hydraulic cam with a bigmouth base,slp runners, 24# SVO'S, 52MM TB 350 block with 85 TPI setup. Please forward me some links from e-bay with some head suggestions that would be a good match for my setup.
Old Jan 23, 2006 | 10:21 PM
Car: 85 Trans Am
Engine: 350 T.P.I.
No input??
Old Jan 24, 2006 | 07:48 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
They are selling refabbed 305 heads . Well the 416 casteing is anyhow. They only have pressed in studs . They springs arent THAT great. But if it's in your price range ...go for it . But they are way better choices out there.
Old Jan 24, 2006 | 11:23 AM
Shagwell's Avatar
also, how do you know your compression w/o knowing what heads you're gonna use? - not possible - Why not look into Vortecs?
Old Jan 24, 2006 | 04:48 PM
Car: 85 Trans Am
Engine: 350 T.P.I.
Will vortecs work with my TPIS bigmouth intake?? Also what is the cost of aluminum vortecs?
Old Jan 24, 2006 | 08:46 PM
Shagwell's Avatar
the aluminum vortecs(Fastburns) will bolt up to your TPIS base, with thick intake gaskets. Regular iron vortecs won't. You can mod them to accpet it, but everyone bashes people who do(I've done it a few times now, no problems) as for pricing(on the fastburns), unless you find a good used set, you could buy much-better aftermarket heads for less $.
gta90
Sep 15, 2015 04:00 PM
509 camaro fan
Sep 6, 2015 10:43 AM
NinjaNife
Aug 23, 2015 11:49 AM
86White_T/A305
Aug 17, 2015 12:16 AM
