Throttlebody leak?
Old Jan 31, 2006 | 02:32 PM
HisDivineShadow's Avatar
Car: 1991 Trans Am GTA
Engine: 350 TPI (L98)
Transmission: TH-700r4
Throttlebody leak?
When I removed my airbox I saw that the inside of the throttlebody was filthy, look like oil has been running there.
I have attached an image so you can see for yourself.
Is this indicative of a bigger problem or is it common?
Old Jan 31, 2006 | 02:38 PM
jsel's Avatar
Car: 1989 iroc conv
Engine: L03 TBI
Transmission: 700R4 soon to t5 from hawks
have you been using oil!
Old Jan 31, 2006 | 02:40 PM
No siree I haven't been using oil, as fuel anyway!
The whole cars insides are quite filthy from the oil-treatment the car got in autumn 2004, it protects from rust, finally gotten around to cleaning out my engine now. Maybe thats it? Though I dunno how it could have gotten in there!
Old Jan 31, 2006 | 03:14 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Are you sure it's oil and not some type of rust solvent?
Old Jan 31, 2006 | 03:16 PM
Not really sure what it was, I wiped it away and all thats left of it is that photo, I was worried it might be a serious problem causing it.
Old Jan 31, 2006 | 03:18 PM
It looks as if someone has hooked up the PCV valve to the throttle body of some sort. Perhaps your throttle body is leaking coolant that need to be replaced.
Old Jan 31, 2006 | 03:31 PM
Sorry, do I need to replace my throttlebody or the coolant?
Old Feb 13, 2006 | 05:51 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
I'm guessing that's unfortunately normal. I think it's from the PCV valve. probably due to "reversion" or some such scientific theory. same as on carbureted motors, the carb air horn gets oil-vapor-fouled. I'll bet your IAC valve (pintle) is also fouled. Mine was also fouled. had to use a lot of solvent spray (e.g. brakleen) to get it cleaned. but then it fouled again after a while. I think it's the motors' way of telling you time for a valve job or rebuilt. I suspect there was lots of oil "blow-by" due to bad sealing, either the valve-stem seals, or the oil-rings on the pistons. I'd guess this was typical for a high-mileage motor. mine had 200k+ miles on it before I replaced the heads (and disconnected the PCV valve). no smog checks here. Unfortunately, now I'm venting oil vapors to "the atmosphere", right into my cowl vent plenum and to the AC vents and the interior of the car. It's absolutely great.
Old Feb 13, 2006 | 06:26 AM
I tested the PCV valve, i could blow one way and the other as well but it was much harder to blow one way. Should a funtioning PCV valve seal one direction completely?
Later this year when I am going to polish my plenum and runners I also planned to replace the gaskets there as well as on the valve covers. I hear that with the valve covers off you can check for carbon deposits that might clog and cause this behavior.
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
