Modified Air Intake
Subscribe
Apr 3, 2006 | 07:16 PM
Does anyone have any pic to show?. Here's mine. On the dyno it was worth 9 hp.
Modified Air Intake-5.9l-355cu-engine-437hp.jpg   Modified Air Intake-att00008.jpg   Modified Air Intake-att00018.jpg
Reply 0
Apr 3, 2006 | 08:56 PM
Does that not let unfiltered air in?
Reply 0
Apr 3, 2006 | 09:08 PM
Dude! look at it again. It's the stock intake modified for Camaros only.
Reply 0
Apr 3, 2006 | 09:29 PM
Not to sound like an idiot, probably too late , what exactly did you do?
Reply 0
Apr 3, 2006 | 09:49 PM
I'm not following either....
Reply 0
Apr 3, 2006 | 09:53 PM
Looks like he broke off the stock nexked down part of the air box where it goes into the rubber boot. Then plastic welded a piece of 3 or 4 inch round PVC to it.
Reply 0
Apr 3, 2006 | 10:07 PM
Just looked at my car, I get it Cool. I'd do something like that but I got MAF. Might not work.
Reply 0
Apr 4, 2006 | 07:54 PM
Quote: Looks like he broke off the stock nexked down part of the air box where it goes into the rubber boot. Then plastic welded a piece of 3 or 4 inch round PVC to it.
You're Right. It makes the neck a full round 3in opening. On the dyno it showed 9hp gain without tuning.
Reply 0
Apr 5, 2006 | 03:28 AM
Good job! Ive thought about doing the same. Ive seen something similar done. The stock design is good just restrictive.
Good gain..How did you do it? How do you weld plastic? I thought about raising the roof also. I think i would have room with the ss hood. If not cuting and refiberglassing the area.
Reply 0
Apr 15, 2006 | 08:17 PM
Anyone know if a mod like that would still work if you have a MAF ??
Reply 0
Apr 16, 2006 | 07:11 PM
How do you get around the MAF, if possible?
Reply 0
Apr 16, 2006 | 07:16 PM
I was thinking about using the holes where the fog lights are to route the air intake to the filter and then into the plenum
Reply 0
Apr 16, 2006 | 09:16 PM
Quote: How do you get around the MAF, if possible?
You can convert to Speed Density fuel management using a 1227730 ECM.. Hopefully what he did..
Reply 0
Apr 16, 2006 | 09:32 PM
thanks i might try to do that, right now im having IAC problems
Reply 0
Apr 16, 2006 | 09:41 PM
thanks i will consider that , im having IAC problems right now
lol didnt mean to post that twice
Reply 0
Subscribe
