Engine hits brick wall
Old Apr 6, 2006 | 07:55 PM
z282slo's Avatar
Car: 91 z28
I'm looking for a few friendly opinions from those who have been there before me. My engine starts to nose over at around 56-5,700 and hits a brick wall right around 6K. With AFR 195's, HSR, and a cc306 cam (230/244). I understand this cam is supposed to be shifted around 6,500 to get the most out of it. I'm suspecting my 5 yr. old stock replacement fuel pump. Thanks in advance.
Old Apr 6, 2006 | 08:51 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
how about that five year old fuel filter or the ignition module?
hook up a fuel pressure gauge and rev it...
Old Apr 6, 2006 | 09:16 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Right. You may be running out of fuel at the higher rpm's. Your engine may be trying to make more horsepower than the pump can put out.
Old Apr 6, 2006 | 09:28 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
fuel/ignition is a good place to start....What are you running for exhaust? A restrictive exhaust will kill the topend.
Old Apr 6, 2006 | 09:31 PM
z282slo's Avatar
Car: 91 z28
Edelbrock TES, no cat, 3 in. to single 40 series flowmaster, MSD 6AL
Old Apr 7, 2006 | 07:38 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
If you have the stock AFR springs, you may be running into valve float, which'll act as an internal rev limiter. I know of others with AFR heads that had to swap out the valvesprings due to this problem...
Old Apr 7, 2006 | 11:29 AM
brutalform's Avatar
Have you done any tuning?
Old Apr 7, 2006 | 09:06 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
I'll second the valve float idea. That really stops a motor from revving. It'll also tend to break valve train components. That's a lot of cam, so I'd really look into new valve-springs first.
Old Apr 10, 2006 | 09:10 AM
z282slo's Avatar
Car: 91 z28
fuel pressure turned out o.k. going to try a set of comp 987's thanks for the replies.
evilstuie
Jan 9, 2020 08:29 PM
mhatfield 14
Oct 24, 2015 07:48 AM
MY87LT
Aug 17, 2015 08:43 AM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
