will removing EGR and smog make my tpi run lean?
Old May 19, 2006 | 01:39 PM
sauer_power's Avatar
Car: 82 Firebird SE
I was told by putting a EGR block of plate on that my tpi and removing the smog pump my car will now run lean. I have a 305 MAF engine.
Old May 19, 2006 | 01:49 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
unless you reprogram the prom the car will not run right and you will have a check engine light all the time. You gain no performance by removing the EGR. The air pump you may gain slightly if removed.
Old May 19, 2006 | 01:50 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
Axle/Gears: posi disc 3.23's
https://www.thirdgen.org/egrdiagnose
"Most people like to disable the EGR because they claim that hurts performance. In actuality, disabling the EGR can hurt performance"
Old May 19, 2006 | 01:52 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
EGR is good. It lowers the EGT during cruise (Part throttle).
Old May 19, 2006 | 02:15 PM
Guest
Guest
Posts: n/a
EGR does exactly nothing for performance at WOT. It can hurt performance though when it becomes dirty/clogged and sticks open. This doesnt usually happen on a SBC but happens all the time on other cars I've had. As far as removing it on a MAF car, I've done that numerous times and never once have I seen a check engine light.
Old May 19, 2006 | 03:54 PM
brutalform's Avatar
The time you would want to remove the EGR, and more importantly, remove it from the prom, is when you use an aftermarket intake, and/or cylinder head that does not have an EGR provision, or passage. The ECM will still continue to "look" for the signal. If you do not do this, a check engine light will result. I know this from my own experience with my S/D. Not sure about MAF, must be different as madmax has stated.
Remove the AIR, and you will run leaner than 14.7 (stoich).
Old May 19, 2006 | 08:56 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Removing AIR will NOT make you lean (assuming you remove it and block the holes). AIR pumps air into the exhaust manifolds during cold startup/warmup, then pumps to the middle of the cat after closed loop is entered, then to atmosphere during WOT. It never pumps into the intake manifold (the only way it could affect AFR).
Old May 19, 2006 | 09:43 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I've removed both and never a check engine light
1992rs/ss
Jan 31, 2025 05:10 PM
NBrehm
Aug 25, 2015 11:49 PM
camaroken83
Aug 10, 2015 11:35 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
