sensor help on a tpi
Old May 20, 2006 | 05:44 PM
83 scrambler's Avatar
Car: 83 CJ-8 (Scrambler)
Axle/Gears: (F)Dana60/(R)GMcorp14/locked 4.11
first off, before people jump on me, i have searched quite a bit, and can't find what i need. does anyone have pictures of the different sensors on the tpi, IE: egr, cts, map, maf, tps, etc. i just want to make sure i know what i am looking at. i have a jeep with a transplanted (not by me) 305 TPI, and i want to make sure i know what sensors are what before i start changing **** around. thanks everyone
oh and sorry for swearing. i am starting to get at my wits end with this motor. it is so powerfull when it runs well, but thats only about 10% of the time
Last edited by 83 scrambler; May 20, 2006 at 05:45 PM. Reason: Automerged Doublepost
Old May 20, 2006 | 05:55 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i think the best thing to do is get a good repair manual for what year TPI setup you have, that way you'll have any wiring diagrams & trouble shooting trees you may need too
Old May 20, 2006 | 06:00 PM
yea
I have been wanting to do that, but seeing as that i dont know what year the motor is, and i can't seem to find the data plate on the motor (either due to stupidity or it not being there) i am unsure of what book to buy. are all TPI's the same? i can't even really determine if i have map or maf because i dont know where the sensors are supposed to be. i think 85-89 305 tpi is my best guess right now. the block is stamped like cfi 551 or some ****, but i assume that is for the block only
Old May 20, 2006 | 06:09 PM
DENN_SHAH's Avatar
look on the ECM,.. it should have some numbers on it, the number will look something like 1227165, or 1227730. it could be some other number, but these should give you an ideal of what to look for.
a MAF system has a sensor in the air intake boot, its hard to miss.
Old May 20, 2006 | 06:13 PM
thats what i had been under the assumption of. there are no sensor before the intake manifold. the air box/hoses have none. the first sensors are in pretty much on the opposite side of the plenum from the throttle/tranny cable hookups. there are 2, one facing forward and one facing out to the passenger side, lower than the forward facing one
Old May 20, 2006 | 07:00 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
Can you post some pics. of the motor???
Old May 20, 2006 | 07:03 PM
sure..probably be a few hours though.
Old Jun 7, 2006 | 11:28 AM
chevycamaroiroc's Avatar
Car: 87 Chevy Camaro Iroc-z
Engine: 350tpi
Axle/Gears: 3:27 POSI
I need some help i have a 87 350tpi irocz with a 700r4 and it idles well, but whenever i rev it while its in park to high rpm like around 3000and up after that when u take your foot off the gas it goes like it wants to die out and starts stumbling a little with the idle,like its not getting enough air or something,i was told it could be my idle air control valve,any one no's what it could be?i would appreciate it
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
