305 TPI, injectors not firing, need all help
Old May 28, 2006 | 09:48 PM
manbeastusmc's Avatar
I have a 91 z28 with a tpi 305, the other day it was fine, i shut it off for a few minutes and it wouldn't start back. It turns over fine, I have spark but doesn't even try to start. I have fuel at the rails, but no guage to measure pressure. The fuel pump is only about 8 months old so I believe the pressure is fine. I checked for power at the injectors and have a good power at both prongs. I don't have a noid light to test to see if the injectors are firing but I did with a test light and nothing(I also lisened to them through a screwdriver). So I said the injectors aren't grounding, the Haynes manual said that the computer or wiring to is bad. I looked over the wiring and found nothing (witch i couldn't look over thoroughly because it was still in the plastic cover) so i replaced the computer with a refrubrished one, still nothing. Then I called a mechenic here in town and he said that it grounds through the igination system (like a TBI) so i checked the coil, pickup coil, module, cap, and rotorbutton. All was fine. So that is where I am I have accomplished nothing and don't know what else to do aside form taking it to a shop any help would be apprecated.
Old May 29, 2006 | 12:31 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Need to find out what exactely the fuel preasure is
Old May 29, 2006 | 06:49 PM
83 scrambler's Avatar
Car: 83 CJ-8 (Scrambler)
Axle/Gears: (F)Dana60/(R)GMcorp14/locked 4.11
i had a very similar problem with the same engine. it was flooding occasionally and didn't want to restart after it was warmed up. i checked the coil and found it wasn't grounded all the way through like it was supposed to be. also my TPS sensor was way out of wack, which caused most of the flooding to stop after readjusted.
Old May 29, 2006 | 09:23 PM
It's not flooding, no fuel on plugs, no smell of fuel
Without the right pressure wouldn't the computer still ground the injectors to spray?
thanks for the input though
Old May 29, 2006 | 09:26 PM
it should be. i just brought up the coil for another reason. without being grounded all the way through, i fired it up and watched, the coil was punching voltage through one of the other wires on it. i was concerned that excess voltage punch through could be messing up sensor voltages. not sure what 7 trillion volts going around the car could cause.
Old May 30, 2006 | 08:49 AM
mine won't start at all, but there is spark
Old Jun 2, 2006 | 09:54 PM
hey everyone still need help thanks
Old Jun 5, 2006 | 04:29 PM
gooter's Avatar
Car: 85 z28 camaro
Engine: 5.0 TPI
I'm having the same problem on my 85 tpi right now. I checked everything like you. Just bought a noid light and it seems that it blinks once and thats it, ecm not grounding the injectors (my car guru friend thinks). Sometimes after fighting with it for a while the pulse will come back. See if you can borrow a noid light or even better, an ecm.
9192camaro
16
Feb 3, 2019 12:21 AM
gta90
Sep 15, 2015 04:00 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
