vortec tpi intake
Old Jun 6, 2006 | 07:41 PM
bluemoon's Avatar
vortec tpi intake
i just bought a gmpp vortec tpi intake and was wondering if there is a plate that is supposed to bolt to the bottom. it didnt come with one and i dont know where to get one. can i use it without one?
thank you.
Old Jun 7, 2006 | 02:46 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Take it off your stocker or get one used.
Can still order from GM to I believe.
Basically its just an oil splash shield to keep it off the bottom of the intake.
later
Jeremy
Old Jun 7, 2006 | 09:53 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Yes, you can use it without it... I kind of forgot to transfer it from my old intake the first time... No ill effects...
Old Jun 7, 2006 | 10:21 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
if you decide to use one, make sure you thread lock the screws. Just a little is plenty, but it prevents them from loosening.
Old Jun 7, 2006 | 10:35 AM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Im pretty sure i seen on on ebay for practically nothing.
eBay Motors: TPI L98 Tuned Port Injection Oil Galley Windage Tray GM (item 8071007139 end time Jun-07-06 19:15:00 PDT)
Old Jun 7, 2006 | 05:10 PM
bluemoon's Avatar
ok. truth be told though, i figured it was just like the heat shield off a carbed motor that ive ripped a few off already.
i bolted this gmpp intake on and now when i got to looking it appears that one of the retaining bolts for that plate go all the way through into one of the intake runners. thats bad.
can anybody confirm this?
Old Jun 8, 2006 | 07:31 AM
jwscab's Avatar
Engine: Many
can't confirm that. I used a scoggin-dickey manifold. It might be an EGR port or cold start passage? If not, ya gotta pop it off, and stick a bolt in there to seal it up.
Old Jun 8, 2006 | 10:06 PM
bluemoon's Avatar
im sorry it is a sdpc vortec base not a gmpp.
here are the pictures the holes come into 4 of the runners. the holes dont go straight down though they go down at an angle.
Old Jun 8, 2006 | 11:06 PM
XSVortex's Avatar
I've been running mine without the tray for about 3 months now, no problems to speak of. It's just the stocker though, not vortec.
Old Jun 9, 2006 | 07:19 AM
jwscab's Avatar
Engine: Many
they look like egr passages or cold start. Unless you can stick a peice of wire up through the bolt holes for the mounting screw and see it poke through, those holes should be there. If you see the wire, then you need to plug the holes with loctited bolts.
1992rs/ss
Jan 31, 2025 05:10 PM
Fast355
Dec 2, 2016 06:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
