New Dyno Numbers for Stockish TPI
Old Jul 4, 2006 | 11:16 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Went to Camaro Superfest this weekend in MI and had the new motor and car on their Dynojet. Best run was 239 RWHP and 338 RWTQ
. This motor was built for a blower in mine so the compression is low.
Besides a fully forged 355 lower end, 8:4:1 compression and an LPE216 Cam the TPI is stock. Stock heads, intake, runners, plenum, injectors, TB and even the stock chip.
Any suggs?
Oh we also went with the 1.5 rockers to keep the lift down for the blower. Cam specs are around 213/219 465/472
Old Jul 5, 2006 | 10:24 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Put on the blower. That compression is killing you.
Old Jul 5, 2006 | 01:02 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
As is the stock intake.
Old Jul 9, 2006 | 09:55 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
But it helps torque!
That helps torque! haha
Last edited by 87TPI350KID; Jul 9, 2006 at 09:55 PM. Reason: Automerged Doublepost
Old Jul 10, 2006 | 08:41 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Are you running exhaust as well? IE Headers and a catback? I know my car stock was 214, and a buddy of mine, who's 91 was also stock, running about the same #'s, bumped his up to around 235 just tossing some hedman shorties on there. You have a cam in there as well. With that low compression I wouldn't expect much without the blower. I would think mine, stock, with a 216 would be in the 230's, with headers, exhaust, 250's doesn't seem that far fetched. Throw some heads on there and really take advantage of the power you will make with the blower.
Old Jul 11, 2006 | 08:57 PM
those are good numbers with low compression
Old Jul 12, 2006 | 11:14 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I got 251 rwhp with mods in my sig . Untunned. I say that is pretty good. Whatwas the air temp there , also elevation ? I am in Ontario so not sure if that made a difference in powr because of elevation or not
Old Aug 3, 2006 | 11:13 AM
formul8!!'s Avatar
Car: 2004 GTO
Low compression helps torque?
Old Aug 3, 2006 | 02:31 PM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
Just out of curiosity, how does it idle with the LPE cam and stock chip?
Old Aug 3, 2006 | 06:46 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I was there also, its a shorter drive for me. I wish that I know that you were going, I would have looked for you these.
Your numbers are very good,,, as above, get that blower on that engine.
Old Aug 3, 2006 | 09:56 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Car runs and idles perfect with the stock chip. We took the car on the power tour, carlisle show in PA and superfest in MI. 3200 miles in one month and we were getting arounf 23 MPG with 3.42's Car runs fine on the stock chip.
Air temp was mid 80's and maybe 500 feet above sealevel? I dunno its near detroit.
1992rs/ss
Jan 31, 2025 05:10 PM
1984HO
Mar 19, 2021 11:59 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
