Can someone identify this wire please?
Old Jul 5, 2006 | 03:24 PM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
I have a blown (read: burnt in half) ground wire that mounts on the passenger side rear of the engine bay, right behind and a bit to the left (pass side) of the engine. It is a large wire, braided copper. What does this attach to and what does it ground?
Old Jul 5, 2006 | 03:33 PM
jonarotz's Avatar
Car: 91 Z28
This is a ground strap that grounds your engine and body together. I would reccomend replacing it. What caused it to burn?
Old Jul 5, 2006 | 04:12 PM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
I shorted the battery to the wheel well. It wasn't pretty. I wish I had found this thing a week ago before I replaced the ECM and MAF trying to get the gremlins out. Ah well, live and learn i suppose.
Old Jul 5, 2006 | 06:02 PM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
Ok, I got a new ground strap but I cannot see/find where it attaches to the engine. There's a bolt that sits on the rear of the passenger side head/valve cover area but it has a couple wires attached to it already, is this it? if not, where? and is it something I can easily do myself? things look very cramped in that area.
Old Jul 5, 2006 | 06:28 PM
camarojustin's Avatar
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
You can pretty much put it wherever you want as long as it's metal it will function as a ground, one of the tranny bolts will work too!
Old Jul 5, 2006 | 07:08 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
It is suppose to go along with the other grounds attached there on the cylinder head, so that is the correct assumption.
Old Jul 5, 2006 | 08:51 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Yes goes on the passanger side up top. When I took out my smog pump I had to remove it and put it back on. Its a pain in the butt!
Old Jul 7, 2006 | 06:09 PM
nothing a 9/16 stubby wont reach.
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Redwhisper
Aug 26, 2015 05:02 PM
Linson
Aug 21, 2015 02:12 PM
Street Lethal
Aug 14, 2015 08:25 PM
