Ignition upgrade recommendations
Old Sep 16, 2006 | 02:40 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
I am looking to replace my stock remote mount coil, cap, and rotor with some quality aftermarket pieces. Can anybody recommend a quality brand that will provide better performance? I can smell fuel in my oil and I need to do a tune up anyways. I was thinking that a hotter ignition would help aid in complete cylinder combustion and possibly add a few horses....
Old Sep 16, 2006 | 03:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Upgrading the ignition would provide no benefit over properly working stock parts.
Old Sep 16, 2006 | 03:42 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Yeah, but that isn't the main concern... I'm looking for suggestions on which company I should go with. Accel, MSD, Mallory, etc... What is the most reliable?
Old Sep 16, 2006 | 10:42 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Go with MSD coil 8226. Mounts in the stock location. Keep your stock GM module in the dizzy. Go with either MSD or Accel cap and rotor. Lastly, a set of 8mm spiral core ignition wires. I run the Taylor Spiro Pro wires on my car, work great. That's about as good as you can go without spending a LOT more money on an MSD box.
Old Sep 16, 2006 | 11:12 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
msd or hypertech coil, cap, rotor, and wires (hypertech doesnt make wires) accel is junk.
Old Sep 17, 2006 | 03:23 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Accell cap and rotor are crap, just like there plugs and wires, stay away.
Buy a blue standard cap and rotor(brass terminals)
Its the same as MSD without the BS price.
I like the MSD 8/8.8mm wires and last longer with headers than other brands I have used.
Replace coil if ancient high mileage, Delco or comparable equivelant.
For the module run a AC Delco and dont forget heat sink compound.
later
Jeremy
Old Sep 17, 2006 | 05:59 AM
qube's Avatar
Car: 1988 Pontiac GTA
If you've suffering from that you're running rich, curing that will add more horses than swapping out the ignition.
M.
Old Sep 17, 2006 | 07:18 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
i paid $300 for the MSD 6AL kit.
it came with coil cover,coil,6AL box, and all wires.
i have a proform cap and roder.
if your willing to pay the price. i think it works nice on mine.
but iam not stock.
ive seen people with the hypertech cap and coil , with good wires of corse, make nice ganes.
Old Sep 17, 2006 | 08:50 PM
Dave Farr's Avatar
Been down that road and dumped the 6A, accel/pertronix modules. Stay with good stock type wires GM/NGK, MSD coil, good hd cap. Reliability is king and the other modules cost me towing- I love buying 'high perf' anything, but GM got their modules working better than anyone else's- MSD told me that their replacement computer controlled dist runs a GM module. The Accel module worked good when it worked.
Old Sep 20, 2006 | 11:21 AM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
I'm running the Hypertech coil, cap, and rotor kit on a stock L98. It made a noticeable difference after I opened the gap on the spark plugs to sixty.
Old Sep 20, 2006 | 01:56 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Stock GM parts for your ignition would work just fine.
Old Sep 20, 2006 | 01:57 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
A sixty gap sounds way too large for a stock L98.
Old Sep 20, 2006 | 01:58 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Old Sep 20, 2006 | 02:06 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Old Sep 20, 2006 | 03:07 PM
screaminyellow's Avatar
Car: '91 RS/'89 Z-28
Engine: 305TBI RS/350TPI Z-28
Transmission: AOD's in both
Axle/Gears: 3.42 RS/ 3.73 Z-28
The stock GM HEI is accually really good @ its job. A new coil and a good set of plugs ( opened up ever so slightly ) and spiral core 8mm or better wires are more than what most people are ever going to need! Don't trow money away on high dollar boxes and Dizzy's, in most cases these high$ parts will cost you more money in the long run due to too much spark energy that can cause tracking in the cap, cross ignition in the wires, and possibly accelerated wear on the plugs.
Old Sep 21, 2006 | 08:33 PM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
I tried an Accel module in the distributor & I think it just puked in less than a year & less than 1000 miles stick with the Delco module!!
I have the Taylor wires & Msd cap & rotor. They seem good. Stay away from the fancy plugs too. AC Delco plugs are just fine.
Old Sep 23, 2006 | 03:08 AM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Thanks for all the info guys... Im now leaning towards the stock AC Delco parts.
Old Sep 27, 2006 | 12:28 PM
formul8!!'s Avatar
Car: 2004 GTO
Regular replacement AC DELCO parts are fine for a stock motor.
I used with success:
-MSD coil
-MSD 8.5 wires (never use Taylor- JUNK)
-Accel cap/rotor
-Bosch Platinum plugs gapped at .45
-stock module (never had one go out on me)
Old Sep 29, 2006 | 05:53 PM
MiTHRiL's Avatar
Car: 93 TA, 92 GTA, 91 TA
Engine: LT1, L98
Transmission: T-56, 700R4
Axle/Gears: 3:23
For MSD wires, what part # do you guys use? I have a 92 GTA with edelbrock headers... I see so many different sets and I dont know which to get. Angled boot or stock, blah blah blah. Any advice? I have some heat shield wraps I currently put over the plug head to protect from the heat from headers.
seiplentz
Aug 19, 2019 06:02 PM
MM2Robinson
Oct 1, 2017 09:16 AM
Fronzizzle
Feb 9, 2017 09:31 AM
Necron
Brakes
Sep 14, 2015 12:45 PM
Jlanz55
Sep 6, 2015 02:35 PM
