What head intake runner CCs for this cam?
Old Oct 9, 2006 | 08:46 AM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
I currently have a comp cams H-roller with 210/220 duration @.050 and .500/.510 lift. I'm assuming I want to stay with a fairly small intake cc on the heads I pick, but just how small is too small (or how big is too big)?
Old Oct 9, 2006 | 10:35 AM
zz4monte's Avatar
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
I would run 170-200cc with that cam.I think the best heads for that cam are the AFR 180cc heads but they are expensive and have a long wait or so I have heard.I have heard nothing but good things about edelbrock E-tec 170cc heads.Basiclly a aluminum vortec but they flow a little better.Are you on a specific budget?Do you want aluminum or cast-iron?Vortecs are usally the best bang for the buck.Also GM high performance has come out with a new vortec head that measures 175cc and has 2.00 1.55 valves unlike the 170cc 1.94 1.50 that are in the stock vortec but they are more expensive.The flow numbers are supposed to be about equal to the 170cc edelbrock e-tecs.
Old Oct 9, 2006 | 11:49 AM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
Thanks! Yeah I'm looking at Vortecs as well as Pro-Comp Aluminums and Darts on Ebay. Just haven't made up my mind yet. AFRs are too pricey for my taste.
Old Oct 9, 2006 | 12:10 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Just remember, if you get stock vortec's on ebay, they will have to be modified to handle that lift....
Old Oct 9, 2006 | 01:33 PM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
The vortecs I'm looking at are the aluminum large-ports that will handle up to .550. But I think I'm going to go with non-vortecs regardless. I have a new polished vortec Stealth Ram, but I don't want to cut up my hood and I'm not sure when I'd be able to afford a different hood, so I think I'll stick with TPI and sell the stealth ram. Plus, the cam I think would work much better with a good TPI setup up.
Old Oct 9, 2006 | 02:43 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
stay around 170-180...no more
Old Oct 10, 2006 | 08:38 AM
GOY's Avatar
GOY
There's no reason he can't go 185-190 if velocity was kept as evidenced through a flow chart.
Either way, thank god someone is selling a stealthram.
Old Oct 10, 2006 | 09:03 AM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
After talking extensively with a couple friends I think I'm going to make the smart choice and go with AFRs, 180cc. Lead time sucks from what I hear, but it's winter soon anyways and I can wait.
GOY: Think I'll have any trouble selling the stealth ram? I'll list it here before I put it on ebay, I should have it today and I'll take pictures.
Old Oct 10, 2006 | 11:07 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
you wont have any problems sellin it i dont think
and 180s from AFR is a great choice.. usually 190+cc heads want alot more airflow from bigger cams and bigger cube motors....and that cam is small. not a good match. u'd have no low end power/tq....... 180's with that cam is a nice match and should make plenty of grunt
Old Oct 10, 2006 | 04:25 PM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
Got the stealthram and man is it pretty:
http://host.giant.net/~darkgunner-we...s/DSCF0021.JPG
I also may not have a hood clearance problem after taking some measurements....What to do what to do! I'm guessing I'd see some nice gains up top but low and mid range would suffer with my cam.....
Old Oct 10, 2006 | 05:25 PM
HD4mula's Avatar
Great choice. I suggest calling ADPerformance as he had some of the new Eliminator in stock. I got mine on first call two weeks ago.
AFR SBC 180cc Street Heads***NEW Eliminator Series*** Discount AFR 180's In Stock @ ADperformance.com
Old Oct 11, 2006 | 06:17 AM
GOY's Avatar
GOY
No, I think selling the HSR would be pretty easy...
Given that you're in Ohio and one day may want to sell your car locally (let's say up by Cleveland), you would probably want an intake with an EGR anyways. Not that I'm pro-superram or anything.....
Old Oct 13, 2006 | 09:21 AM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
One thing I forgot to mention was I do have a 2400 stall converter. will this still do well with the 210/220 camshaft, or do I need to go a bit larger? Also, where do the edelbrock runners fall in terms of type- LTR or more like the SLPs? I'd like to go with Edelbrocks if I can. Just trying to make sure I have all my parts in order. Here are the final specs on my combo, any suggestions welcome.
AFR 180cc heads, 68cc combustion chamber
9.5:1 comp
comp cams 210/220 @.050, .500/.510
TPIS big mouth intake manifold
(Edelbrock) Runners
Ported plenum
Stock Throttle Body
30 lb/hr injectors
1 3/4" MAC headers
4" mufflex exhaust
2400 stall
3.73 rear
I'm looking to break into the 12s or so. super low 13s wouldn't break my heart, either. This car is mainly going to be a show/cruiser, however.
Just trying to make sure my cam fits well with everything else I have/plan to get.
Old Oct 13, 2006 | 09:58 AM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
The Trickflow heads have a really nice minimum cross section on their 195 cc heads. They should be able to maintain a good port velocity with a 195cc head.
(bore x bore x stroke x rpm x .00353/614)=Minimum cross section.
...........................sq inches........port cc
edelbrock performer rpm ....1.43.............170
vortec......................1.66.............170
tfs195......................1.93.............195
afr 180.....................1.93.............180
afr 195.....................1.98.............195
afr 210.....................2.05.............210
dart pro 200................2.06.............200
dart pro 215................2.14.............215
brodix track 1 .............2.30.............221
dart pro 1 230..............2.40.............230
edelbrock 23 high port .....2.53.............238
edelbrock 18 deg............2.71.............266
tfs 18 deg..................2.80.............250
Old Oct 14, 2006 | 08:13 AM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
Would I need to change anything in my combo to go to those 195s? I ask because of the significant waiting list for the AFRs, and to my knowledge Trick Flow doesn't make a 180cc intake head.
Old Oct 14, 2006 | 10:55 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
trick flow makes a 175cc head but i'd stick with the 195. only thing i could see changing is going to a slightly bigger cam. stealth ram + 350, i would run a 220/230 cam or somewhere in there. comp cam 224/230 is a nice grind. lpe 219/219 is nice too. zz409 226/226 is nice as well
Old Oct 14, 2006 | 11:18 AM
shaggy56's Avatar
Car: 71 Nova
Heres one of Trickflows articles on the 195 heads.
Trick Flow Makes Serious Horsepower
Type: Small block Chevy, 383 cubic inches
Compression: 10.1:1 (Trick Flow heads), 10.8:1 (L98 heads)
Reciprocating Assembly: Trick Flow 3.75" forged crank and 5.7" forged rods,
Keith Black hypereutectic pistons with -12cc dish
Camshaft: Comp Cams hydraulic roller, 230°/236° duration @ .050, .510"/.520" lift
Rocker Arms: Trick Flow roller, 1.5 ratio
Induction: Edelbrock Victor Jr. manifold with Holley 750 cfm double pumper
Ignition: MSD Billet distributor and 6AL ignition
Exhaust: Hooker 1 3/4" primary headers, 3" dual exhaust with 2-chamber
Flowmaster mufflers
The engine made 460hp and 450 tq.
One also nice note about these heads.
[Trick Flow Specialties 23 Degree 195 Aluminum Heads part numbers
TFS-30400001, TFS-30400002, TFS-30400003, TFS-30400005, TFS-30400006, and TFS-30400007 have been found not to reduce the effectiveness of required vehicle pollution control devices, and are therefore exempt under California Vehicle Section 27156 permitting the advertising, sale, and installation of these parts on 1995 and earlier 262-400 c.i.d. small block Chevrolet V8 gasoline engines.
Old Oct 17, 2006 | 09:33 AM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
Okay, I ordered a set of AFR 180cc Eliminators with the 65cc chamber (in stock at ADP!). Now my question is, compression ratio. with Iron heads and my cam I was recommended 9.5:1; since I'm going aluminum, what do I need?
Old Oct 18, 2006 | 06:40 AM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
trickflow 175cc heads
I was thinking about going with the trickflow 175cc heads and a 218/224 duration at .50 and .495 intake lift and .503 exhaust lift and for the intake tpis big mouth and as&m runners and port the plenum. How are these heads i figured the 195cc would be too big for tpi also what will the 56 combustion chambers do to the compression ration on my 350 with stock 62cc heads? Im also thinking of running 9 bolt 3.70 gears and a 2800 stall torque converter.
Jake_92RS
Jan 28, 2020 10:37 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
