Throttle body spacers
Old Oct 30, 2006 | 10:35 PM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
Has anyone had a lot of success or noticed any real power gains with a throttle body spacers. I searched and only came up with stuff for TBI units and I was wondering how they affected TPI setups.
Old Oct 31, 2006 | 07:21 AM
Iroc-E-89's Avatar
Car: 1989 Iroc Z
Engine: 5.7
Axle/Gears: 3:73
I have just found and ordered one at aaxel.com Its a Jet Performance Tpi throttle body spacer Part # JT-62102 Like $120 not bad ! Check it out !
Old Oct 31, 2006 | 10:03 AM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
I was also wondering if these make any difference or if it's worthless similar to an air foil. And Also Iroc-E-89 tell us how it turns out and als that better make a hell of a difference for $120. And on a side note I was thinking depending on how large it is, Is it possible to have fitment issues as far as the snorkel getting to crammed. Let us know man
Old Oct 31, 2006 | 11:46 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
That spacer is for a TBI setup...
Do they even make spacers for TPI? I doubt it, I can't see it having any effect.
Old Oct 31, 2006 | 04:53 PM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
I didnt look at the link but i know for sure they sell them for tpi's because ive seen them
Old Oct 31, 2006 | 05:35 PM
formul8!!'s Avatar
Car: 2004 GTO
Why would want to make the air have to travel any farther than it already does to get to the cylinder?
Waste of money.
Old Oct 31, 2006 | 07:06 PM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
Waste of money.
It's got to do with changing the path of the air.
Old Oct 31, 2006 | 10:02 PM
formul8!!'s Avatar
Car: 2004 GTO
On a TPI motor? the LAST thing you want is to create turbulance in the plenum.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
