What happened to My IROC
Old Nov 6, 2006 | 08:58 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
The strangest thing happened just a hour ago. I was at the drive window at Sav-On when my car started lopping as if it was about to run out of gas, only it has a full tank. It would start for a few seconds going cacunk, cacunk and then die. I called AAA and while waiting for a Tow truck (20 minutes or so) and try it again and amazingly it starts right up and runs normal, except for a strong odor (like burnt rubber) and I drove home.
Now I'm afraid it might do it again. Any thoughts would be appreciated.
Old Nov 6, 2006 | 10:40 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
TUNE UP including fuel filter, also invest on getting the injectors cleaned
Old Nov 9, 2006 | 04:50 AM
IROZINCO's Avatar
fuel pump
you may be loosing your fuel pump, though i don't know where the burned rubber smell would come int.
Old Nov 9, 2006 | 10:46 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Might be burning spark plug wires
Old Nov 15, 2006 | 11:02 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
I did all of the above, but the same thing happened again tonight and after 15 minutes of waiting it started up and ran fine. Could this be a case of vapor lock? Is it possible for a fuel pump to act up one minute and then start working fine the next?
Old Nov 16, 2006 | 06:39 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
have your ignition module checked at a local parts store
Old Nov 16, 2006 | 07:46 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Originally Posted by ringo234
...Could this be a case of vapor lock? Is it possible for a fuel pump to act up one minute and then start working fine the next?
Act up, Yes, Vapor lock no - difficult to do when the pump is submerged in gasoline and as you stated the tank is full.
Old Nov 17, 2006 | 06:44 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
id say def a fuel pump. when they burn out they overheat. you can run it until the pump warms up then it will die. you might be able to limp on it for a while as long as you have a FULL (and i mean full) tank of gas. the gas will cool it down to a point but you still need to replace it.
good luck, changing a fuel pump sucks major a$$ on our cars unless you cut your hatch floor...
Red iroc-z 305
Sep 30, 2015 05:22 PM
BewleyBizzIROC
Sep 7, 2015 08:05 PM
jharrison5
Aug 19, 2015 05:53 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
mustangman65_79
Aug 11, 2015 03:17 PM
