Fuel Pump Recommendation
Old Nov 19, 2006 | 04:50 PM
vanceh's Avatar
Hello,
My in-tank stock fuel pump died in my 5.7, TPI, MAF 87 GTA. I've already removed the tank and since the job is a PITA one which I don't care to repeat, I think it's a good idea to install something better then OEM. Can any of you Trans-Am guru's offer any suggestions what would be a good quality/performance fuel pump?
BTW: I replaced my stock injectors with #24 and installed an adjustable fuel regulator and gauge.
Thanks in advance,
Old Nov 20, 2006 | 03:48 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Go to http://www.racetronix.com/ and get the TPI / L98 Camaro / Firebird / GTA High Performance Fuel Pump Kit with Plug n' Play Harness. Its well worth the money. Comes with Walbro pump GSS307M or GSS340M.
Old Nov 20, 2006 | 05:10 PM
Drac0nic's Avatar
+1. If you want local get one for a 91 Syclone, it's still got more flow then the stock L98 pumps do, Buick guys used em a lot in the day.
Old Nov 20, 2006 | 05:15 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
what he said
Old Nov 21, 2006 | 02:45 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Buy a Walbro.
Dont buy a Holley or a granatelli or any other people who just repackage "Walbro's", you'll save money just buying a Walbro lol
later
Jeremy
Old Nov 23, 2006 | 01:44 AM
vanceh's Avatar
Pump Selection
Hay guys,
Thanks for all the recommendations, seems that everyone perfers the Walbro pump. I was searching on Summit's website and was concidering either the Holley HLY-12-914 for $159 or the BBK with sells for $129. They both push 255 liters per hour.
I looked at the Walbro GSS307M which sells for $159 on racetronix. They don't say much about the pump itself, they say the performance comes from their cable harness with delivers power to the pump directly from the alternator. The idea is they use larger gauge wire to reduce voltage drop which in turn keeps the pump running at higher speeds.
Their kit includes the pump, strainer, o-ring, cables, connectors, relay and fuse. If you consider the cost of the electrical parts, do you think their pump is of equal or better quality compaired to the Holley or BBK?
If so, then do you think the Holley is over priced as it sells for the same price?
Would I notice a performance difference if I purchased the Walbro compaired to the other choices? I'm also very concerned about how long of a life the pump will last as I don't care to drop my fuel tank again.
Old Nov 23, 2006 | 01:50 AM
3.8TransAM's Avatar
Originally Posted by 3.8TransAM
Buy a Walbro.
later
Jeremy
People dont read what other people post do they?
Yes buy the one with hot wire kit.
Personally I have never had it be an issue on my cars, but older ones or abused ones very well could use it and/or if your in doubt
Old Nov 23, 2006 | 02:23 AM
IdroolforTPI's Avatar
junk the TPI, go carb and run a mechanical pump. Problem solved. 2 birds one stone
Old Nov 23, 2006 | 02:26 AM
TPI4lyf's Avatar
also.... kill yourself for buying a thirdgen in the firstplace
Old Nov 23, 2006 | 02:50 AM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
Goodbye TPI4lyf and IdroolforTPI
Old Nov 23, 2006 | 12:38 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Old Nov 23, 2006 | 01:50 PM
vanceh's Avatar
Fuel Pump
Hi Jeremy,
One of your past post you said don't buy from people who repackage Walbro's. Are you saying that BBK and Holley are actually Walbro pumps?
If that's the case, then I will be ordering the Walbro with the hot wire kit.
I'll probably go ahead and wire in a hidden kill switch for additional security.
Thanks for your help,
Vance
Old Nov 23, 2006 | 04:30 PM
Drac0nic's Avatar
Originally Posted by vanceh
Hi Jeremy,
Vance
yes, all the 255 Holley/BBK pumps are is a re-labeled Walbro. The hot wire kit can make a significant difference when you get into an application near the edge of the pump's ability, and the lower voltage drop of the new harness will make your pump last longer. The stock harness is on the edge of marginal from the factory in all honesty, it's 14 or 16 gauge..
Old Nov 24, 2006 | 10:07 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Thunder Racing is a distributor for Racetronix and they're having a 10% off Thanksgiving sale as well. I bought my hotwire kit from them during their last 10% off sale and only paid $75 shipped. Check out APEUSA, they've got good prices on Walbro pumps. I got my pump from them for just under $90 shipped.
Old Nov 24, 2006 | 10:44 PM
WillSpeedy's Avatar
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
Dam I didn't know they made a hot wire kit. But I do have a walbro pump coming in the mail.
Old Nov 25, 2006 | 01:07 AM
3.8TransAM's Avatar
Be wary of who u buy Walbro pumps from.
Only buy them from legitimate vendors like Racetronix and Full Throttle.
There have been a lot of fake ones that are inferior products being made and sold as walbro's
Word to the wise.
Forgot about that sooner in the post
A true Walbro will have Walbro or there W on it, I think the fakes dont
later
Jeremy
Old Nov 25, 2006 | 01:35 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
[quote]
later
Jeremy
I think I remember reading on turbobuick.com the real ones have the 'W' stamped on there, while the made in China versions are laser etched.
But yes, buy from a well known vendor and you'll be ok. And I'd probably avoid the ebay ones just in case.
EDIT: I guess they're not really laser etched but they do engrave the logos on them. I found the rest of the post I mentioned.--->http://www.turbobuick.com/forums/gen...t=walbro+china
Old Apr 15, 2007 | 03:45 PM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
Re: Fuel Pump Recommendation
or if you jjust need pump http://www.fuel-pumps.net/
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
