52mm or 58mm TPI Throttle body
Old Nov 20, 2006 | 10:38 AM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
The time has come for me to decide which to get. I'll be running a 9.2:1 compression 5.7 with Edelbrock E-tec 200
heads, a Comp Cams XR276HR hyrdaulic roller with 1.6 rockers, 3.42 rear gear and T5 trans. The plenum has been
Max-Ported along with the SLP runners by Mikey Graycar and an Edelbrock base. What do you folks think?
Old Nov 20, 2006 | 03:47 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
My opinion is that a 52mm throttle body is fine for a 350. I would use a 58mm for engines 383 or larger, and/or those with forced induction.
Old Nov 20, 2006 | 05:18 PM
'Shifter's Avatar
Car: 87 Z-28
Could it hurt anything?
Old Nov 21, 2006 | 12:01 AM
Kevin91Z's Avatar
No, but it could make idle tuning tougher, because you're getting more air than you need.
Old Nov 21, 2006 | 02:30 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Idle tuning, light throttle conditions as well and alot of playing with IAC constants to make it truly behave like stock again.
The larger TB's like the 58mm also play havoc with the AE settings.
later
Jeremy
Old Nov 21, 2006 | 11:43 AM
dave-92gta's Avatar
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
you could might also think about chipping your car. fixes all those problems. read the tech articles on that. you will be swamped till you read it like 3 times, but its worth learning to do it yourself for later aplications
Old Nov 21, 2006 | 11:50 AM
'Shifter's Avatar
Car: 87 Z-28
Much appreciated guys....I forgot to mention that I am already 'chipped'.....
Old Nov 21, 2006 | 01:41 PM
Shagwell's Avatar
Car: projects.......
Run the stock 48mm. Rig a vac gauge up for temporary use(zip ties & wiper arm....etc). Once it's up and running good, find out if you have any vacuum @ WOT/max rpm. If you have vac, then worry about upping the TB size. If not, why go larger? To make tuning more difficult and to loose some throttle response?
Honestly, I doubt that combination is gonna need more than the stock 780 cfm.
Old Nov 25, 2006 | 05:57 PM
formul8!!'s Avatar
Car: 2004 GTO
48mm may be enough for this motor combo.
Old Dec 26, 2011 | 11:52 AM
Hunter0075's Avatar
Car: 91camaro Rally, work in progress
Engine: 5.7 350. 400hp 400ftlb torq
Transmission: turbo 350
Axle/Gears: stock rs rear, 3.23.
Re: 52mm or 58mm TPI Throttle body
Did the tpi's come with a 52mm stock or a 58mm? If a 52mm stock can I install a 58mm and would i have to bore the plemn out?
Old Dec 26, 2011 | 02:59 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
They came with twin 48mm TBs. For either the 52mm or the 58mm you'll have to port the plenum.
Old Dec 26, 2011 | 03:13 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
I agree with Kevin91Z. Get a 52mm (or stick with stock sized 48mm, in my opinion). No need for anything bigger. Bigger is not always better when it comes to throttle bodies.
I had a hard time finally deciding to buy a 58mm for my engine, and it's a 383 with a 244/254 .608 .608 110 cam, ported heads, and a ported intake, and it will be rev limited at 6800 rpm. AND it's a shorter LT1 intake (it's an LT1 engine), to boot.
Old Dec 26, 2011 | 03:35 PM
BuzzLOL's Avatar
Car: '87 GTA Black/Black/Gold & others
Engine: TPI 350" & others
Transmission: Many
Axle/Gears: Many
.. X 2... doesn't sound like you're above what the stock 48mm TB can handle... yet...
Old Dec 26, 2011 | 07:23 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
What do u mean "your already chipped"? Have u already installed and had the car tuned for those Edelbrock heads? cam,etc?
Old Dec 26, 2011 | 07:36 PM
gp90gta's Avatar
Car: 1990 GTA
Ninetyone thats an old post from 06, anyways the stock 48 is good for up to 450fwp and maybe even more but I can say 450 for sure.
Old Dec 26, 2011 | 07:43 PM
BuzzLOL's Avatar
Transmission: Many
Axle/Gears: Many
.. 'Hunter', what's your current engine combo? Different than your signature, I assume...
Old Dec 27, 2011 | 10:05 AM
Hunter0075's Avatar
I have a 5.7l 400hp
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
