TPI vortec
Old Jan 16, 2007 | 09:39 PM
Iroc'n 87's Avatar
TPI vortec
I have been doing some searching to find out wether or not I can take advantage of the vortec heads and still keep the Tpi system. I stumbled across this website. http://www.chevyhiperformance.com/te...e_vortec_head/
It is very possible to have a vortec TPI engine. All that you need is a Vortec TPI compatible manifold. Just thought that I would share with everyone.
Old Jan 16, 2007 | 09:41 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
You are correct. Edelbrock makes that manifold to.
Old Jan 16, 2007 | 10:07 PM
drexton311's Avatar
Car: 1989 T/A
SWEET!!! I know what I want!
Old Jan 16, 2007 | 10:38 PM
TurbomanKnight's Avatar
Car: 1983 Recaro T/A
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
How about if one were to take the complete Vortec Engine and put that on, would it work?
Old Jan 17, 2007 | 10:54 AM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Transmission: NV4500
Axle/Gears: 4.10
I think I might personally consider that to be a bit of a downgrade myself... The Vortec engines are already multi-port, sequentially injected engines with manifolds well suited to the engine. Switching it out to a mid 80s batch fired multi-port system isn't gonna help it a whole lot...
Would probally work alright though!
Old Jan 17, 2007 | 07:42 PM
Jaxom's Avatar
Car: '89 IROC-Z
Engine: StealthRam 355
Transmission: 6-speed
Axle/Gears: 3.70 9-bolt
What you do is take a Vortec engine, harness, ECM and all and put the TPI system on top. You'll have to rewire the injector connectors, but you'll have sequential MPFI on a long-tube runner intake, and since DIY tuning is supported for the Vortec ECMs you can get the calibration right and have a great torque maker with the efficiency of sequential injection. The only issue I can forsee is whether you could find a distributor cap for the Vortec dizzy that will clear the driver's side intake runners.
Old Jan 17, 2007 | 11:46 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
I've had the Scroggins-Dickey high-flow intake system with GMPP fast burn alum heads on my '88 IROC-Z with '89 eprom since 2001.
I would like SEFI, but I haven't researched enough to know what PCM/harness I need to keep my small-cap HEI distributor, LTx opti-spark is out of the question. LSx is distributorless and I think a better option, but would intail adding cam & crank sensors.
Old Mar 2, 2007 | 04:05 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Vortec distributor cap on TPI
Do I need the complete Vortec distributor to get the horizontal wire configuration?, or will the cap fit on my TPI small cap HEI distributor?
Tinbender59
Mar 17, 2017 10:50 AM
Fast355
Dec 2, 2016 06:33 PM
z28addict8490
Sep 5, 2015 03:56 PM
earlpote
Aug 28, 2015 10:42 AM
Sanjay
Aug 12, 2015 03:41 PM
