cam help
Old Feb 15, 2007 | 09:59 PM
ajk511's Avatar
Car: 1991 z28
cam help
trying to decide wich cam setup would be better for my 350 tpi. right now im stock, but the cam will be going in with reworked heads and a Holly Stealth Ram. i dont know much about cams so any help is appreciated.
Cam that some of the NIFBA guys helped me pick out, just dont know if its too big for my needs or not.
http://store.summitracing.com/partd...15&autoview=sku
LT4 HotCam
http://store.summitracing.com/partd...02&autoview=sku
Old Feb 15, 2007 | 10:30 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
what year motor do you have.
Old Feb 16, 2007 | 04:36 AM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
I don't mind running the numbers with DynoSim but I need more information.
Old Feb 16, 2007 | 11:14 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
also is it a MAF setup too ? Or SD ?
Old Feb 17, 2007 | 12:51 PM
ajk511's Avatar
Car: 1991 z28
its a 1991 350 running speed density. thanx for the help guys
Old Feb 17, 2007 | 08:21 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Well the first cam listed is a flat tappet cam. The 2nd cam is for an LT-1 and of course a hydraulic roller cam. So like was posted above what block do you have?
Old Feb 18, 2007 | 12:02 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
the LT4 cam hands down, but you will need a chip to even get it to run.
good luck.
Old Feb 18, 2007 | 09:14 PM
ajk511's Avatar
Car: 1991 z28
good luck.
I was planning on buying some prom programming equipment cuz i figured i would need to reprogram my computer to work well with the cam and some other things. anything special i should know?
Old Feb 21, 2007 | 10:20 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Yeah ! Everything !!!!! . I would go hit the DYI/ECM board ....start reading
Old Feb 21, 2007 | 09:38 PM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
definately the LT$ hot cam! i have it in my 383 and it rocks!
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
