witch valve stem seals to buy?? and tools
Old Feb 19, 2007 | 12:21 PM
wannafbody's Avatar
Car: 88 GTA
Axle/Gears: 3.27 9bolt
Im going to be changing my valve stem seals asap, I just dont know witch ones to buy, umberella? positive o ring? I duno. A part number would be good and i dont wanna do this twice.
Im also chaning to 1.6 rr's with new springs anything else I should look into? locks retainers?
I am not sure of witch tools to get either, I have a good air compresor but no fitting for the spark plug hole and I cant seem to find the valve spring compresor everyone says to use.
Thanks and any help is greatly apreciated.
Old Feb 19, 2007 | 12:39 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Forget the stock o-ring garbage.
Get the applicable viton seal and be done with it for the intakes.
Use the umbrella on the exhaust and u will be good to go.
later
Jeremy
Old Feb 19, 2007 | 01:21 PM
wannafbody's Avatar
Car: 88 GTA
I found these i think these are the GM replacements
http://69.20.110.81/index.asp?PageAc...D&ProdID=22805
will this valve spring compresor work?
http://store.summitracing.com/partde...2&autoview=sku
Old Feb 19, 2007 | 01:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Use Fel-pro SS72527. That compressor is low-tech, but it'll work fine.
Old Feb 19, 2007 | 06:17 PM
wannafbody's Avatar
Car: 88 GTA
what about this compressor?
Are those fel pros ad good at the GM ones?
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
Old Feb 19, 2007 | 06:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That type of compressor works fine, too.
The Fel-pro positive seals are much better than the factory O rings. They're similar to the ones in your link.
Old Feb 19, 2007 | 06:31 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i'm actually hoping to replace my valve springs and go to 1.6 rockers as well this spring. I have heard you can get a compression testing hose and use that to insert into the spark plug hole
else you can use a old spark plug and hollow it out. i've seen someone suggest that.
Old Feb 19, 2007 | 06:41 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Those work if you have access to compressed air. If you do, you can also buy an "air holder" for a couple of dollars at the parts store.
If you don't have an air compressor, a length of nylon rope works.
Old Feb 25, 2007 | 09:27 AM
wannafbody's Avatar
Car: 88 GTA
so i can use the intake seals for the exhaust also?
Old Feb 25, 2007 | 12:27 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I use intake seals on the exhaust, or you can use umbrella seals.
trevor1010
Aug 26, 2015 02:41 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
trevor1010
Aug 24, 2015 08:34 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
