TBI to TPI
Old Mar 6, 2007 | 07:51 PM
95 4x4's Avatar
Car: 1995 Chevy 4x4
Engine: 355 cu. in. Vortec / TPI / MAF
Axle/Gears: 3.73 Limited Slip
TBI to TPI
I have a 95 4x4 chev and the TBI is not cutting it for me anymore and would like to go TPI . For starters can the ECM ( 16197427 ) (BJYL ) be modded so it can run TPI .
Old Mar 6, 2007 | 09:53 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
check www.tbichips.com I think he talks about it some on there.He did some kind of similar swap or do a search on here i know its been covered and i think some of the ecms are compatible but not sure.I`m wanting to swap my old 305 tpi into my truck which has a turd of a4.3 tbi JUST CHECKED MYSELF.I dont think they are.I think some of the v-6 and v-8 ecm`s are compatible but not to the tpi.This was a quick check so check our tech articles or our engine swap board.i know its coverd in one or both of those.
Old Mar 7, 2007 | 03:59 PM
95 4x4's Avatar
Car: 1995 Chevy 4x4
Thanks i will search some more , i know i seen it also but i haven't come across it . Their is alot of good info on this site .
Old Mar 7, 2007 | 10:35 PM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
check www.hotrodlane.cc
Old Mar 7, 2007 | 10:52 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
For starters, I am not a huge fan of TBI to TPI on a stockish engine. It is just not worth the money spent for the gains given. You are better off with headers, appropriately sized exhaust, a mild cam, and a torque converter upgrade, along with the supplemental tuning.
The PCM HAS been used to run TPI, search the DIY Prom board for Haulin's post when he converted his son's 1994 305 to TPI.
On the other hand a stockish TBI setup can feed 300+ HP at the crankshaft and produce plenty of torque, especially OFF-IDLE where the TPI won't make as much torque. One of my 350 builds put down 279 RWHP/340 RWTQ with an un-touched throttle body(big block injectors) and stock GM intake manifold.
This was playing around with a cold TBI engine the other morning.
Fullsize G20 Van with 3.08 gears, 350 TBI, ZZ4 cam, TPI 305 heads, Headers, Duals, tuning.
http://youtube.com/watch?v=p2kH39oC8O0
http://youtube.com/watch?v=sNgHi85M6AY
Old Mar 8, 2007 | 01:16 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
[QUOTE=Fast355;3255137]For starters, I am not a huge fan of TBI to TPI on a stockish engine. It is just not worth the money spent for the gains given.
You still beating on that drum?
Old Mar 11, 2007 | 01:24 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Questions:
1. When you say untouched throttle body, are you saying it was a 305 throttle body, or it was a 454 throttle body that you didnt mess with?
2. WHat heads were you using to get 279hp. That's about where Im aiming at with a build I'm planning, right around 300... Something reasonable, fuel efficient, and streetable.
Old Mar 11, 2007 | 06:21 PM
95 4x4's Avatar
Car: 1995 Chevy 4x4
The TBI motor i currently have does have Vortec heads with the matching intake along with modded Tbi and 90 lb injectors , cam , headers , tuned chip which took a year to fine tune . Yes i did see the article from Haulin A$$ and that is what i was looking for after searching till my eyes bugged out . From what i have read the TPI set-up is right up my alley for torque and also looks impressive .
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
Dwayne614
Sep 28, 2015 08:33 AM
Sanjay
Aug 12, 2015 03:41 PM
