Looking for a lumpy cam
Old Mar 18, 2007 | 10:32 AM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
Okay, I've already got a strong motor and my cars fast, but it's time to rebuild, so I'm ready to shoot for more, over 500 hp, maybe 600, haven't decided yet. I'm going to build a new engine and I want a cam with attitude. That's right, when Ricky Racer pulls up next to me I want to see fear in his eyes just from the sound of the cam.
I want a cam that will work with our EFI that is streetable. I've got a good idea of what I want but I can't hear the cam before hand so I'm asking my fellow TGO brethren to help me out here. My cam talks a little at idle, but not much, not enough. I used to have a 1972 Mustang Mach 1 running a built 351 CobraJet (601 hp) with a Crane Fireball 302 cam. That was a thumping cam, I'm talking it would make the hair on the back of your neck stand up. That's what I'm talking about, a cam that dares anyone to mess with you. I know I can't get the same nasty loping idle as the fireball cam, not with EFI, but I want some tone. TALK TO ME!!!!!
I'm also trying to decide between a SuperRam and a StealthRam, so chime in on that if you feel like it.
Thanks Amigos!!!
Old Mar 18, 2007 | 08:34 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
LT4 Hotcam.
Old Mar 18, 2007 | 08:43 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
63-08-467-8 Comp Cams XFI Camshaft, 230 / 236, .576 / .570 113 LSA, Strong mid-range and top end power. Headers, exhaust, gears, converter, computer tuning recommended.
that'd be my pick for either of the intakes you chose.
or this one 63-08-468-8 Comp Cams XFI Camshaft, 242 / 248, .584 / .579 113 LSA, Good midrange with excellent top end power. Headers, exhaust, gears, converter, computer tuning recommended.
http://thunderracing.com/catalog/?ac...&vid=6&pcid=51
Old Mar 19, 2007 | 09:15 AM
I've heard the LT4 hot cam, no attitude there.
3rdGenZ have you heard either of those cams in a car?
Old Mar 19, 2007 | 10:34 AM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
no, but the first cam should have roughly the same amount of overlap as my cam. here's what it sounds like
> http://www.youtube.com/watch?v=AA0TVcY6U0U <
i have a 218/230 cam with a 112 LSA
Old Mar 19, 2007 | 10:51 AM
Yes, your cam has some attitude, sounds good. I'm going to see if I can find sound clip.
Old Mar 19, 2007 | 03:29 PM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
i dont know any of the specs but have you looked at comp cams new thumper series cam"s yet?
Old Mar 23, 2007 | 08:33 PM
Re: Looking for a lumpy cam
The Thumper series are retrofit cams for original flat tappet cam motors and they have tight LSA's, not made for computer controlled EFI motors.
Old Mar 24, 2007 | 12:51 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Streetable and lumpy camshaft are opposite words, but I suppose that depends on your definition of each.
Stealthram if you dont have emissions testing, Superram if you do. Just be prepared to do your own custom chips (that's for anyone else reading this)
Old Mar 24, 2007 | 10:14 AM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
What is your idle rpm with this? What are your lift figures? what cam is this?
Old Mar 24, 2007 | 05:05 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
i still need to tune it but with the stock chip about 650rpms
the lift is .459/.486 its a crane 268 Z cam
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
