Rough runnin tpi wtf ?????
Old Apr 23, 2007 | 06:12 AM
Iroc-E-89's Avatar
Car: 1989 Iroc Z
Engine: 5.7
Axle/Gears: 3:73
Hey Guys Hope someone can give me a little insight here! Ive got an 89 5.7 TPI with A.I.R delete and headers with no cats w/ 118k.All else is stock. Car starts up nice,runs good untill it builds up a little heat and then starts to bog and get a surging idle. Under driving conditions it has lost some power and seems to go into TQ conv. lockup way too early.And when you come to a stop it starts shaking and bucking with the surging idle. I cant figure this out and its really starting to get to me! I got a code 24 once and a code 32 once,not at the same time and not recurring,wich is kind of making me think its the ecm??
Im about ready to take the Ford Hammer to it(thats my 20 lb sledge)!!
I have replaced so far
1. MAF & Burnoff relay
2. EGR Valve
3. Iac
4. ICM & Coil
5. CTS
6. Cap & rotor
7. Plugs & wires
Hope some can help me out here! Any info would be great!Thanks in advance guys!
Old Apr 23, 2007 | 07:41 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Re: Rough runnin tpi wtf ?????
hows your timing and your fuel pressure?
Old Apr 23, 2007 | 07:43 AM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
I have this problem too, but I was thinking to blame it on the cat converter because it rattles while idling. I think its clogged and choking the engine.
Old Apr 24, 2007 | 06:17 AM
Iroc-E-89's Avatar
Car: 1989 Iroc Z
Engine: 5.7
Axle/Gears: 3:73
Im pretty sure the timing is okay ,due to a recent top end re-build. Will check though. Fuel pressure is okay too, about 45 psi. I have no idea what could be causing this.What kills me even more is its not throwing a code! Any one ever heard of the pick up coil causing this condition?
I dont have any cat converters either!
Old Apr 25, 2007 | 05:14 AM
Dave87IROCZ's Avatar
Oxygen sensor. Is your fuel pressure steady or does it bounce? I doubt its the pickup coil. Possibly a tempeture sensor.
Old Apr 25, 2007 | 06:00 AM
Iroc-E-89's Avatar
Car: 1989 Iroc Z
Engine: 5.7
Axle/Gears: 3:73
Checked the timing last night, a little off ,so I set the timing NO change! Whatever it is seems to be killing my oil pressure.It drops pretty low at idle.Also I seem to be blowing oil out of the dip stick tube.I changed the coolant temp sensor also. This is driving me flippin nuts!Fuel pressure seems pretty steady!
Old Apr 25, 2007 | 08:08 AM
Engine: LB9, LB9
Im going to check my timing and fuel pressure too.....my oil pressure drops at idle too and I get oil around my oil sender and I even replaced it. Sounds like we have a similar problem. I was thinking that my injectors had sat so long that they are trash.
Old Apr 25, 2007 | 08:31 AM
joecautela's Avatar
-I would ck that biz of oil coming out the dipstick and sender. Is the PCV valve plugged or your valve cover breather clogged? Could be your getting too much backpressure in the top end. It would make the mtr act like it's constipated. I've seen it before, Joe
Old Apr 25, 2007 | 10:51 AM
Iroc-E-89's Avatar
Car: 1989 Iroc Z
Engine: 5.7
Axle/Gears: 3:73
Im gonna try the o2 sensor tonite, as thats pretty much the only thing I havent replaced! I had ordered new injectors, the ford 22 lb-ers but when i went to install them the rings around the top of the injector,where the clips go that lock them into the rail,didnt line up right. The stock injector only have one groove for the clip but the ford ones seem to have two or three grooves and dont lock into the rail right. Anyone had this problem?? Maybe I need new clips also?? I can post a pic if you dont understand what Im talkin about.Sorry for gettin off the subject. Ive also been thinking maybe the distributor is all together bad causing the erratic idle and loss of oil pressure. Im stumped!!! Thanks a million for all the suggestions I wish one of them was the culprit!!!
Old Apr 25, 2007 | 09:15 PM
You dont need the looking clips. The ford injectors are a little shorter than stock ones. You may want to grind down where the fuel rail mounts to the manifold. I put the ford 24s on and had them leak twice. If I had known they were shorter I would have used different ones. Its probably your oxygen sensor.
Old Apr 26, 2007 | 01:08 PM
Iroc-E-89's Avatar
Car: 1989 Iroc Z
Engine: 5.7
Axle/Gears: 3:73
Im pretty sure the injectors I got are actually longer than the stock ones.I really hope its the o2 sensor gonna put the o2 in tonite Ill let ya's know how I make out! Thanks for all the help guys I appreciate it !!!
Old Apr 26, 2007 | 04:15 PM
Iroc-E-89's Avatar
Car: 1989 Iroc Z
Engine: 5.7
Axle/Gears: 3:73
Well I changed the o2 sensor and it is running a little better but not much.I also adjusted the IAC after installing the o2.Idle is a little smoother but still also a little rough. It also threw a egr code today, came on for a second and went right back out! Still blowing oil out the dipstick too,pretty bad.Also still having an issue with the torque converter locking up too early.Could a bad egr or solenoid cause that??? This is killing me, the weather is gettin nice and I cant even drive the B*tch!!!
Old Apr 27, 2007 | 07:34 AM
Engine: LB9, LB9
The Egr valve went bad on mine so I changed it and only the light went off, the gas milage was still terrible and it wasnt until after I changed it that it started this running rought trash. That could be the problem though.
Old Apr 27, 2007 | 07:46 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Have you checked your PCV and breather hoses yet?
Old Apr 27, 2007 | 11:25 AM
Iroc-E-89's Avatar
Car: 1989 Iroc Z
Engine: 5.7
Axle/Gears: 3:73
I have checked the pvc and and hoses,all my vaccum lines! All is good! Thats why this is so aggrivating! Im leaning towards somthing internal,maybe a sucked valve or timing chain? Its the buisness with the oil coming out the dipstick thats gettin me nervous. Actually thinking of droppin in a carb and saying bye-bye to the ecm!!!!
Old May 7, 2007 | 05:21 PM
Iroc-E-89's Avatar
Car: 1989 Iroc Z
Engine: 5.7
Axle/Gears: 3:73
Hey all, I replaced my fuel injectors the other day and, problems are gone!!!
Couldnt believe it!! Ohmed out the injectors and had a couple in the 8's,couple 12's and the rest were 15.6 dead on. Still doesnt seem like its "all there", but she's definitely 99% better.Now its time to wheel and deal to try and get an inspection sticker!!haha. Just wanted to let you guys know how I made out,
especially those with the similar problems. Thanks again for all the help guys !
Old May 7, 2007 | 05:30 PM
jetblast's Avatar
Car: 91 z28 convertible
Transmission: 5 speed
What kind of injectors did you buy, and How much?
Old May 11, 2007 | 09:06 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
grind where? and how much do i take off to get the fuel rail lower to adjust for the shorter ford injectors?
Old May 11, 2007 | 09:16 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I've never heard of anybody having to grind the mounting posts on the manifold to get the Ford injectors to fit. I don't have Ford so I can't say from personal experience.
Old May 12, 2007 | 10:30 AM
tranceemotionz's Avatar
Car: 1991 Chevrolet Camaro Z28
Engine: 5.7L TPI L98
Axle/Gears: 3.23 posi/limited slip
i had the same probably in fact ive posted two or three forums about the issue... the dealership misdiagnost my car wrong on three seperate occasions... i took it to a mom and pops shop and turns out i had 6 faulty fuel injectors... the injectors were working but the solenoids inside them had burned up so everytime the car reached operating temp the solenoids would break down causing spurts of fuel (which explains the bucking when at a stop) i changed them out and problem no longer exists....
Old May 12, 2007 | 01:32 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I had oil comeign out my dipstick before. I had a spun bearing . She didn;t last long after that . Also have you ohm'd out the injecotors.
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
jbd1969
Aug 17, 2015 07:06 PM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Sherpajames
Aug 7, 2015 06:56 PM
