1.6 rockers, worth it? please step in
Hey i got a 88 305TPI. it has the self alighning rockers, i was thinking to get a set of Federal Mogul Stamped Steel 1.6 rockers to replace the stock 1.5
worth the 65$ ? will i get a noticible difrence being they add a small amount of lift to the crappy peanut cam?
-Stell
1988 IROC 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans , K & N, 160 Thermostat+ Temp Switch
And Always Trying To Go Faster
-Stell
Car: Turbo Buick
Engine: 3.8 V6
are you sure the federal mogul rockers are self aligning? ive never seen the self aligning type sell as stamped 1.6 for that cheap
if infact they are id say go for it, either way with the peanut cam or the 5 speed cam you are gonna see an improvement. For 65 dollars you cant go wrong either.
FYI im running stamped steel 1.6 crane rockers on my motor but they are non self aligning. I cant tell you what difference it made since i dropped the motor in with a bunch of mods, but everything seems fine.
Car: 91 Camaro Z28
Transmission: TKO 600
Axle/Gears: 10 bolt 3.23
Can you run 1.6 ratio roller rockers on a stock tpi? it's for an L98
Wally
86 IROC with the "unknown motor"
84 Berlinetta
Wally
84 Berlinetta
ya i got the SDPC catalog, pg# 78 partnumber
r-1023r. it says 87up and i called them a while back and was told that they are the self alighning ones. so good buy??? and anotherthing will this cause a major fail in the CARB emmissions test (damn NJ had to adopt it)
-Stell
-Stell
Wally
Wally
I've been using Crane roller-tipped 1.6:1 rockers on my 305 with the "LA" (LameAss) cam and stock springs for about a year with no adverse effects. My research indicated that the power increase on a stock cammed 305 are supposed to be a little over 16 HP and 17 lb/ft of torque, but advertised numbers are always suspect. However, any improvement is an improvement.
Later,
Vader
"Some Body...Someone"
Guest
Posts: n/a
"will this cause a major fail in the CARB emmissions test"
Who is going to notice?
The tailpipe emissions will be just fine, and no mechanic in his right mind will pull a valve cover and see what rockers are in there.
87 up are self aligning, so yea it sounds like a good deal.
What do the 1.6 RRs from SDPC cost?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES Headers, Hooker Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.3 @ 97mph
L98 TPI 350 (5.7L)
Car: '89 GTA
Engine: ZZ6TPI
One problem you may find is that on 87' and later heads, 1.6 rockers cause the pushrod to rub on the cast guide plates since the pivot is relocated closer to the valve. They don't all do this, but you may find that one or more pushrods do because of variations in the casting tolerances. In this case, the heads have to be removed and machined for clearance.
89 Transam GTA, a few bolt ons
Stell,
i went to the sdpc website and they dont have that part #, and all their 1.6 roller rocker arms are like 250$?? whats up
[This message has been edited by ron rizzotti (edited September 12, 2000).]
Ron, Try calling SDPC and ask for Steve.He will get you what you need.Before I ordered my roller tips,I was going to go with the Fed/Mogul stamped 1.6 rockers which are listed for 87 and up.I was a little skeptical,so I called Fed/Mogul and they confirmed it.
We need Perry Mason
We need Perry Mason
Ron, they are in the catalog i ordered from the website, i called them they had them about a month ago
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
I was the first person to actually install 1.6's on a stock engine about 3 years ago. The Crane Gold self-aligning 1.6 full roller rockers work perfectly (same as GM performance parts rockers). I ran these rockers with the stock springs for a long period of time with no adverse effects. IMO, its a great 'bolt on'. It can be done in a few hours and will provide a nice boost. Not only do you get the benefits of lowered friction (definitely go full roller!) you also make the cam *seem* as though it has an extra degree of duration.
Good Mod!
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.587 @ 107.97mph (1.710 60ftr) on the long runner setup.
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels. Stock Wheels. No Weight Reduction.
Gunning for NA 11's with the MiniRam II and Hooker LT Headers.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Good Mod!
Tim
Gunner242
12-25-2015 04:49 PM
skinny z
10-05-2015 06:23 PM
