bogs when given gas
Old Jun 11, 2007 | 01:22 PM
LoneStar666's Avatar
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
bogs when given gas
stock tpi, 383ci with 64cc tbi heads. new blaster 2 coil, ignition module, cap, rotor, spark plug wires, plugs and a 67gph fuel pump. after changing the fuel pump the bogging went away for the most part, but it still does it.
say ill take off from a dead stop and itll get up to about 10mph and then take off, or be in 2nd gear and itll go for a couple seconds and then kick in with like 100 more hp
could the stock fpr with almost 160k miles on it be a possible cause? when i got the car i was told it had 40lb injectors on it, which im not sure if i believe but im pretty positive they arent the stock ones. btw ive already checked all the sensors with a MODIS and they are all working properly.
anyone have a similar problem and find a fix?
Old Jun 11, 2007 | 01:53 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: bogs when given gas
Did you run a vacuum/psi test? What's it read at idle?
say ill take off from a dead stop and itll get up to about 10mph and then take off, or be in 2nd gear and itll go for a couple seconds and then kick in with like 100 more hp...
Old Jun 11, 2007 | 03:08 PM
BA92GTA's Avatar
I had a problem like that. It turned out to be two things. Timming and the TPS.
Timming was off a few degrees. But when I changed the TPS the car would burn out again. Turns out there was a dead spot more or less in the TPS.
Old Jun 11, 2007 | 07:02 PM
Engine: 364ci LS2
Axle/Gears: 3.46
Street Lethal: the car runs @ about 36psi idle, and shoots up to a little over 42psi a WOT
BA92GTA: Timing is @ 6*, and the TPS is .58v closed (have it maxed out)... and i believe that it was something like 4.5-4.7v @ WOT
Old Jun 11, 2007 | 08:26 PM
Street Lethal: the car runs @ about 36psi idle, and shoots up to a little over 42psi a WOT...
How is engine vacuum? Do you have a vac gauge?
Old Jun 12, 2007 | 08:16 AM
Engine: 364ci LS2
Axle/Gears: 3.46
yeah i have a vacuum guage... where should i hook it up on the TPI ? and what should it pull at idle/wot
Old Jun 12, 2007 | 09:46 AM
BA92GTA's Avatar
I agree with Street, get a gauge on it.
TPS...
Ummm.... the numbers you posted are very close to what I was getting.
I guess what I was trying to say is, you can get the correct number at closed and at WOT. However, there in between at half throttle or slightly there under, still be getting a closed throttle voltage.... Or it seems thats what mine was doing....
Good Luck.....
Old Jun 12, 2007 | 03:50 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
BA92GTA, I once had the same problems, the scanner was reading the sensor correclty but it was still bad... I would look into that and my other problem was vaccuum leaks at the EGR valve, very small leak.
Old Jun 12, 2007 | 10:53 PM
Engine: 364ci LS2
Axle/Gears: 3.46
TPS...
Good Luck.....
i checked all the sensors with a MODIS ($8000) and made sure they didnt have any crazy voltage spikes throughout the rpm range/throttle position
pjsparts
Oct 29, 2025 06:39 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Grant2k
Apr 4, 2016 08:21 AM
86maro_252
Oct 10, 2015 06:52 PM
middian
Sep 5, 2015 01:42 AM
