A thought about the plenum
Old Oct 22, 2000 | 06:36 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Would there be any benefit to adding an extention to the top of the stock plenum? I know this sounds far-fetched but would this help? I'm talking about cutting the top off the plenum and adding a box to the top for more air capacity in the plenum. Probably a very stupid idea but wasn't that all the SLP T-Ram was, other then different runner lenght and intake? Thoughts?
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Oct 22, 2000 | 06:55 PM
bigvic's Avatar
You know Ive thought about the same thing but instead of cutting the top out, I thought about adding a spacer between the TB and plenum. Kinda like a carb spacer except much thicker adding more volume to the plenum.
Old Oct 22, 2000 | 08:13 PM
Rob P's Avatar
Engine: ZZ4TPI
I thought about the spacer (keep heat away from the TB) but that would throw off the throttle cable/TV/cruise cable lengths, though there may be enought play to stretch.
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
Old Oct 22, 2000 | 10:41 PM
rondubbs's Avatar
i thought they made spacers for our throttle bodies?
Old Oct 23, 2000 | 05:12 AM
Rob P's Avatar
Engine: ZZ4TPI
The only spacer for TPI tb's that I have seen is a nitrous plate. There are plates for the regular variety TBi (L03).
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
Old Oct 23, 2000 | 06:03 AM
cursedz28's Avatar
Ive seen a spacer for tb. It claimed to twist the air with some spirals and seemed kinda fishy to me. Dont have a clue who makes it, cause it had such a big impact on me.
Old Oct 23, 2000 | 07:31 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
I don't think a TB spacer would do much, volume wise. The difference in volume would be small because of the large volume already present. You'd probably get more from porting the heck out of the plenum. Without changing runner length, I don't think you'll see much improvement.
Old Oct 23, 2000 | 07:37 AM
Ski89Z28's Avatar
In the new Summit catalog (pg 74) There is a spacer you can buy for TPI TB. It doesn't say for camaros or firebirds but you can get the one for the chevy pickups it'll work on our 48mm TB.
There are other companies that sell the same thing but charge double the price!
Old Oct 23, 2000 | 03:55 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
When did chevy trucks ever use a 48mm tb? I thought they went from tbi right to the vortec multiport system that used a single blade throttle body?
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 23, 2000 | 07:27 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Ski, those are for TBI equipped vehicles.
Old Oct 25, 2000 | 05:14 AM
Ski89Z28's Avatar
No, the picture shows it for TPI Throttle Bodies. May be different year, say the 93-95 pickups? You can call them to check it out and they will try to help as much as they can.
I didn't order one so I can't say proof positive but ... call and ask.
Old Oct 25, 2000 | 08:29 AM
Jim85IROC's Avatar
I looked in my Summit catalog last night and the only spacer I saw was an orange-ish spacer that's designed for the TBI trucks. There was never a GM truck that used the double butterfly 48mm throttle body, therefore it stands to reason that there isn't a spacer for it, because people don't make add-on products for devices that don't exist. Well, maybe the government, but they don't count.
The IROC Homepage
tyeo098
Nov 30, 2015 06:27 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
85 Jimmy
Sep 30, 2015 07:56 AM
italiano67
Sep 22, 2015 08:42 AM
IROCZ1989
Sep 4, 2015 11:54 AM
