120 psi cranking compression too low?
Old Jun 26, 2007 | 08:02 PM
ULTM8Z's Avatar
Is this too low for a 350 Chevrolet with 10:1 compression and a Comp Cams 262 roller?
All my cylinders exhibit this cranking pressure during compression testing and leak down tests all pass with flying colors. If 120 psi is too low, what could be the cause?
Old Jun 26, 2007 | 09:42 PM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
Re: 120 psi cranking compression too low?
cause what? Pressure seems ok, they're all about the same...
Old Jun 26, 2007 | 09:50 PM
ULTM8Z's Avatar
In the DIY forum I've been posting for a very long time about a rough idle with very lousy emissions numbers. (and yes, I've gone through every possible scenario on ignition, fuel, EFI system... everything!). I've verified beyond a shadow of a doubt that I have fuel and spark, so the last piece of the puzzle is compression.
After I opened this latest thread today, I've been reading around the internet and other people with similar cams and compression are getting on the order of 160-180 psi. Since all cylinders are the same it makes me wonder if my cam timing is off or something- intake valve staying open too late and bleeding off compression during the compression stroke. That much of a loss can't be having an insignificant impact on combustion... Anyway, I just wanted to run it by you guys here...
Old Jun 26, 2007 | 09:51 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
To me that seems a tad low for a 10:1 motor, but then again cranking pressure is dependant on so many things its not even funny...
If it passes a leakdown test 100% i wouldnt worry one bit about it. 120psi should be still enough to keep a motor running healthy.
Old Jun 26, 2007 | 11:42 PM
Guest
Guest
Posts: n/a
All plugs out, WOT. Are you doing that?
Old Jun 27, 2007 | 08:33 AM
ULTM8Z's Avatar
Actually no.
I guess I need to rerun it.... Should I expect the cranking pressure to go up?
Old Jun 27, 2007 | 11:03 AM
fun Pain's Avatar
Transmission: 4l80e
yes redo, without the throttle open, only the min. air will be allowed to enter. And with the plugs out it will spin faster. (overlooking some of the cam). That will boost the numbers.
Old Jun 27, 2007 | 11:11 AM
ULTM8Z's Avatar
I'll certainly redo it. But, if you spin the engine over enough times, the cylinder will bring in as much air as it possibly can, I would think. My compression gauge works on a cummulative basis- that is, it will add each compression stroke until it reaches a maximum and the cylinder is not pumping in any additional pressure.
Wouldn't the WOT and all plugs out would only affect it if you were to do only one or two rotations?
Old Jun 27, 2007 | 12:13 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Pull the plugs, prop open the throttle blade, charge the battery, and spin each cylinder four times. My engine with 150K mi. was 160 psi.
Old Jun 27, 2007 | 03:45 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Yes, redo. It does make a difference. 120 seems too low. I was pulling 180 cold on all 8 cylinders on my 92 with 92K.
Old Jun 27, 2007 | 05:54 PM
ULTM8Z's Avatar
I just read that a factory ZZ4 pulls about 190 psi. It'd be curious if pulling the plugs yields me another 70 psi.
Old Jun 27, 2007 | 07:55 PM
88 IROC CONVERT's Avatar
Car: 2002 zr2 Blazer 88 Iroc convertable
Engine: 305 T.P.I.
cam overlap on a modified engine makes compression readings inaccurate. I think the best thing to do is
1) take readings on all 8 cyl and compare all about the same should be ok.
2) do a leakdown test, you will need a compressor, back off the rocker arms, hook air line and gage with shut off to the cyl , pressurize cyl and close valve. and wait. do all and compare. good luck
Old Jun 27, 2007 | 08:57 PM
ULTM8Z's Avatar
Don't know if you read the whole thread...
Leak test was done successfully. Cam is very mild- 212° intake, 112° LSA. Not much more radical than a ZZ4. Static compression is 10.1:1. I'd suspect the readings need to be pretty close to a ZZ4 if my engine is setup correctly. The more I'm reading, 120 psi is way too low for my engine combo (though I still need to rerun the test and verify).
Old Jun 28, 2007 | 04:09 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
my machinist's camaro runs at 120psi cranking.. 355 with 10:1.. its a nitrous motor but still runs 12.7 off the bottle.. it is kinda low but facts are facts.. it can work great..
Old Jun 29, 2007 | 10:53 PM
ULTM8Z's Avatar
Well, I pulled all the plugs out and opened the throttle blades...
180-190 psi on all cylinders.
Damn... I was hoping I found the problem.
So I have fuel, spark, and compression on all cylinders, but a lousy idle. Go figure.
Old Mar 29, 2016 | 08:58 AM
justangel's Avatar
My camaro has low compression and at a shop they told me that the engine was done. Should I just get another engine or rebuild mine? Need some advice on this
New camaro owner
Old Mar 30, 2016 | 10:08 AM
bop11's Avatar
Car: 1988 GTA
Engine: VIN F 305 TPI
Transmission: AUto
The reason you need to spin fast and be at WOT is that moving air has inertia. The compression of the engine is not just the Volume at the bottom of the stroke divided by the volume at the top of the stroke times 14.7 (normal air pressure) as you were taught in school. With the throttle closed you are creating a vacuum in the intake which will act to reduce the amount of air entering the cylinder reducing the compression ratio. With the engine spinning fast, the air momentum, (velocity times mass) will cause more air to flow into the cylinder during the down stroke than would if the down stroke was slow. These two factors combine to raise your compression by a factor of 1.5. This is the lowest the car sees when it is running, if the exhaust system is designed as a good extractor.
Those compression numbers look very good. Could there be a small vacuum leak or exhaust problem?
Old Mar 30, 2016 | 10:22 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
What injectors you using? What is base timing set at? Done any tuning for the cam/compression? Whats manifold vacuum look like at idle?
Cornholio7979
Sep 20, 2018 02:31 AM
krisner89
Carburetors
Sep 20, 2015 08:56 PM
fasteddi
Sep 2, 2015 10:29 AM
gixxer92
Sep 1, 2015 04:32 PM
BBSDesigns
Aug 11, 2015 07:39 PM
