Who here runs the LT4 hotcam?
Old Nov 9, 2000 | 11:50 AM
JeffP's Avatar
How would this combo run?
Fresh L98 shortblock, 9:1 compression, Edelbrock 6085 heads, LT4 hotcam, Stock TPI, 24 lb SVOs with custom prom, slp headers, flowmaster exhaust.
Possibility of future intake upgrades like semi-siamiesed runners and new manifold.
Enough for mid 13s?
Old Nov 9, 2000 | 02:57 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
It'll run damn rich with those large injectors and no air coming in to feed them. Turn the fuel pressure down to about 40 PSI, and get some intake manifold mods as soon as you can. At least port-match the intake manifold.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 9, 2000 | 03:31 PM
JeffP's Avatar
What injectors would work better? Also, it would run rich even with the custom programming?
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Don't know yet, I pick mine up Saturday.
Bob '89 Formula CC350
Last(lost)Member of the Elusive Great Lakes Crew
My car's homepage
Old Nov 9, 2000 | 03:37 PM
theformula's Avatar
I was wondering the same thing. Would it work well with a 92 formula 5.0. check my mods out.
'92 Formula
305 TPI
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,Crane AFPR (50psi),MSD6AL,homemade cold air,K&Ns,3:73s,JET fan switch, Macewen white face gauges...ZZ9 cam is coming!
Old Nov 9, 2000 | 03:38 PM
RCR's Avatar
RCR
A custom PROM will prevent it from running rich. The biggest problem is that the plenum/runners/intake in stock form will only support 4500 to 4700 RPM. The LT4 Hot cam will make power til 5500 to 6000 RPM. So unless you make the stock equipment breath better, the cam is out of your powerband.
Old Nov 9, 2000 | 03:47 PM
JeffP's Avatar
Should I look into a milder cam, something like a 210/220 .480/.480? Can yall recommend something in place of the LT4?
Old Nov 9, 2000 | 03:55 PM
RCR's Avatar
RCR
Paul Huryk has some tech articles in the Tech section that really help one understand the numbers for cams. For 4500 to 5000 RPM, stick with a duration @ 0.050 of around 200 to 210. Look for as much lift as the heads will support (from Pauls article). Changing the springs might be necessary. One thing to keep in mind is that the LT4 Hot cam has only 492/492 lift with the stock 1.5 rockers. You can always increase lift by going to 1.6 rockers.
Old Nov 9, 2000 | 08:02 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I don't believe the LT-4 Hot Cam and the TPI style intake is a good match. Get a Superram or a Miniram if you want to unleash the power fo the LT-4 Hot Cam.
Old Nov 9, 2000 | 08:07 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
I'll let you know on Saturday, my engine is going in tomorrow night: ZZ4 short block, Edelbrock 6085 heads, LT4 hot cam, GM 1.6 roller rockers, ported stock TPI, SLP 1 3/4" headers, no cat and a Dynomax cat-back.
I'll let you know how it runs as soon as I do.
Black 88 GTA L98
DEAD
but a new crate engines on the way
E.T.F.A Member #11
[This message has been edited by Scott 88 GTA (edited November 09, 2000).]
MustangBeater20
Oct 29, 2022 09:20 PM
perZ
Aug 21, 2015 05:51 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
