What mod next? Headers?
Old Nov 13, 2000 | 04:57 PM
Casey'91Z28's Avatar
I'm thinking of putting edelbrock headers on my car for my next mod, or should I do something else first? Everything is in my sig. Also TPIS has these headers for $299 is this the best price, it just seems weird that they would have a good price on these when everything else they sell is overpriced.
'91 Z28 305, Auto trans, K&N filters, power pulleys, ported plenum, hypertech chip, hooker cat back, kyb shocks, STB, 14.7@ 93 mph.
Old Nov 13, 2000 | 05:18 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
For a 305 they are fine. I would recommend having them coated though. Coating them makes them last a lot longer, look better and reduces underhood tempertures. I have the Edelbrock TES on my L98 (coated) and after 1 1/2 years and 30,000 miles of all weather, they still look new and shiny.
Also, you are able to touch (or work near them) in 15 minutes. In fact, after 15 minutes, they are cooler than my intake runners.
Old Nov 13, 2000 | 07:56 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I think one of the biggest restrictions in our cars is in fact, the exhaust, so you should fare well with headers. I would like headers to be my next mod, but I'm on a strick budget lately, but that would be my reccomendation.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
Old Nov 13, 2000 | 08:02 PM
ONEFORMULAOVERALL's Avatar
u might want 2 also try slp headers, i have eldb. and love em but slp claims that theirs flow 20% better than eldb. dont know but worth checking! hope it flows 4 ya...
92 F-BIRd FORMULA T-TOP (WHITEKNIGHT) 5.7L-98,700R4B&MSATURDAY NIGHT
SPECIALTRANS 2500STALL,54MM-AS&M TB-PORTPLENT,LARGETUBRUN,
UNDER PULLEYS K&NCOLD AIR KIT,160THERMO,ELDB HEADERS W/3 1/2 Y PIPE 2 RINO CAT 2 4INCH PIPE 2 FLOW,
MSDDIST,6AL,8MMWIRES.
2BLASTERCOIL.ACCELL PLUGS
CUSTOM FASTCHIP BY ED WRIGHT,AUBERN POSI W/ RICHMOND 3.73 AND SPLINES,TUBE FRAME CONNEC
PST KIT.1LE BRAKE KIT! MANY MORE MODS FORESEEN IN MY ERA!13.38ET @ 109.75MPH
Old Nov 14, 2000 | 04:21 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
Edelbrock headers would be a good choice. Despite what many people say on these boards, Edelbrocks are just as good as SLP's. After that you could try a AFPR, Accell ignition, shift kit, bigger gears, etc, etc..........
88 GTA
L98 350
700R4
3:27 axle
MODS,
Edelbrock TES headers, 2.5" straight pipe, Flowmaster 80 series, K&N filter, Accel 8.8mm wires, Bosch Platinum plugs, Wells cap and rotor button, Wells ignition module, MAF screens removed, Hypertech TB air foil, Thermomaster stage II chip, 180* Powerstat, Hypertech cool fan switch, B&M shift kit, B&M power clutch pack, B&M servo, GM fuel filter.
Old Dec 3, 2000 | 09:23 PM
theformula's Avatar
For the PITA headers are to install, you better get stainless steel...that is if you plan on keeping the car.
And there's only one company that has equal length headers that are stainless steel..
SLP
'92 Formula
305 TPI 5speed
1LE package
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,Crane AFPR (47psi),MSD6AL,AC delco cold plugs, Bosch O2sensor, homemade cold air,K&Ns,3:73s,JET fan switch, Macewen white face gauges
[This message has been edited by theformula (edited December 04, 2000).]
Old Dec 3, 2000 | 10:46 PM
Dan87IROC-Z's Avatar
Yes, the TES Headers sound like a great choice.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Soon to come: LT4 HOT Cam, Air Flow Research 190cc Heads, 2800 RPM Stall Converter and SLP 3.70 Rear End Gears.
Old Dec 3, 2000 | 10:48 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I like my edelbrock. I did get them coated too. very nice workmanship perfectfit and nice directions.
89 FORMULA 350 Edelbrock Cat-Back ,March Pulleys,Super Coil,MSD 6AL ,Edelbrock TES's, AFPR ,Shiftkit, Edelbrock Base ,AS&M Runners, Edelbrock Waterpump, Fast chip,1.6 RR's, 24# Injectors.
Old Dec 4, 2000 | 06:13 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
If you get edelbrocks for God's sake get them coated if you plan on keeping your car more than a few years. I'd get the 1-5/8" SLPs though. There is a GP on and you can get a set for $350 which isn't much more than the edelbrocks plus you won't have to have them coated.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
