:mad: Need some help
Old Dec 7, 2000 | 03:41 PM
Viper702's Avatar
I have a 1986 IROC-Z28 305 TPI.The prob that i'm having is that when I start it hot or cold the idle go's up relly high and I have to wait 3 to 5 min for it to go down so I can put it in gear.I've done everything that I can think of to fix the prob.The new part's that I put in are: TPS,IAC,CAP,ROTOR,TEMP SENSOR,I checked all my vac line's,and had my fuel injection system checked and it's okay.I don't know what to do now this has been going on for far to long it's been 3 month's that i'v been fighting with it...Please help Thank's Frankie
Old Dec 7, 2000 | 03:48 PM
Blade's Avatar
If I were you I'd go look in the tech articles section of the main site, and do the IAC reset procedure. Most then likely that's what your problem is.
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components.
Best ET 12.9@107 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Old Dec 7, 2000 | 03:59 PM
Viper702's Avatar
I did that it diden't help.thank's
[This message has been edited by Viper702 (edited December 07, 2000).]
Old Dec 7, 2000 | 04:12 PM
Kyle F's Avatar
Well things that I know that can speed up and idle to high. Timing beinbg set to far in advance, vacume leaks arount the intake track can cause this big time, and sticking throttle bores. Ok for the timing, check it, the procedure is in the tech atrticles. For intake leaks do this, before the car gets warm get a can of carb cleaner and spray a light bit around where ever there is a gasket and listen to see if the idle picks up, if it does there is a leak there. If your throttle bores are sticking ,you would notice this driving it that sometimes you have to tap under the gas to get the gas completly off, you just have to live with it or buy a new TB. Most likely it is a leaking gasket I would try that route first
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank, bearings, rings, and magnafluxed rods. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,SVO 24# injectors,MSD 6A, Hypertech Power Coil, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, MSD Wires, removal of A/C hardware and a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace
http://geocities.com/SunsetStrip/Garage/9548/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/4 ton 350, one of those NASCAR F150's
Old Dec 7, 2000 | 05:37 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Have you tried cleaning the IAC passage ways out?. Just a carb cleaner type operation
Old Dec 7, 2000 | 06:12 PM
Viper702's Avatar
Thank's for the help.I've checked for leaking gasket's with carb cleaner and the timing okay,and I have also cleaned out the tb and all passage's.The idle will go down in time as it's running but I shouldn't have to wait for it to do so...Thank you Frankie
Old Dec 11, 2000 | 12:33 AM
F22Raptor's Avatar
How about the throttle body? Are the blades closing all the way. Mine used to trip every once in a while and a shot of WD 40 or just plain motor oil where the sping is was enough to fix it. It might have something to do with metal expanding when engine is warm, therefore loosening up and bringing the throttle down. just a suggestion
'88 GTA 350
Headers, catback, free mods, Xtreme energy cam, intake pieces and 2100 RPM TQ
*13.40@102.55 MPH* Best New ET
1.90 Sec, Best 60FT
104.23 MPH, Best Trap Speed
Old Dec 11, 2000 | 02:19 PM
Viper702's Avatar
You know what that's a great suggestion,now that I think of it I don't think they do.I think there tiped a bit.I seem's to me that the prob started after I cleaned out the TB with carb cleaner,I know that sound's weard but I think that might be it.Thank's i'll let you know...Frankie
1992CamaroGirl
Dec 25, 2017 08:45 PM
MM2Robinson
Oct 1, 2017 09:16 AM
elevario
Jan 23, 2002 11:20 PM
Roshambo
Pacific Northwest Region
Jan 10, 2002 11:52 PM
89Z
Jan 8, 2002 04:34 PM
