Best CAM?
Old Dec 18, 2000 | 10:23 AM
MY87GTA's Avatar
Best CAM?
What is the best cam for a 87 GTA 350? and about how much do they cost?
Old Dec 18, 2000 | 06:59 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Unfortunately you don't give enough information such as, what are your goals and intended usage, what mods are you planning to (or prepared to) install, is your engine already modded or is it stock, expected/desired fuel economy, emission requirements, all naturally aspirated or willing to use a "power adder", etc.
With a 350, you must also be prepared to live with some compromises due to the engine's size. You can make a 350 turn some very quick times in the 1/4 mile, but usually you have to make some sacrifices like bottom end torque, driveabilty/streetability, longetivity, fuel economy and emissions.
It is impossible to make a 350 to do the 1/4 mile in under 10 secs, pull like a Cummins diesel, idle like a taxi cab, get 30 mpg and pass certain states' emission laws. You might be able to accomplish a few of the above but not all.
Old Dec 18, 2000 | 11:37 PM
MY87GTA's Avatar
I'm adding 1 3/4 w/o air SLP headers a 80 series flowmaster, and SSM traction bars and subframe connectors this winter. I also plan on getting some sort of cold air induction. I thought about adding the Ram air hood but i have heard bad things about it. I have a 9 bolt borg warner rear end with 3.73 gears from rieder racing. I have A MSD 6al box, msd super conductor wires, delco cap, K&N airfilter, AC delco plugs, converter is drilled through, was told i have cam but not sure, told heads were ported and polished but not sure. Also what is porting your plenium? I it hard and how much does it help? My car is a 5 speed, what else is a good effective mod?
Old Dec 19, 2000 | 03:24 PM
Dan87IROC-Z's Avatar
Its a 350 with a 5 speed, wow. I'd go with the LT4 HOT Cam, you're mods are more extensive than mine, and thats the one I am getting, its only $190 from Salee Chevy.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Next on the list: LT4 HOT Cam
Old Dec 19, 2000 | 04:10 PM
MY87GTA's Avatar
Where is salee chevy?
Old Dec 19, 2000 | 04:11 PM
MY87GTA's Avatar
What do you mean when you say "free mods"?
Old Dec 20, 2000 | 05:35 AM
Ski89Z28's Avatar
Free Mods are modifications you can make to the car without spending any money or very little, usually less than $20 to $30 if you have the tools.
The "tech aritcles" from the home page here have most of them. Some free mods are:
Throttle Body coolant Bypass
Porting/Matching the Plenum
Home Made Ram Air
There are more but I think you get the jist of it.
Good Luck!
Old Dec 20, 2000 | 08:13 AM
bad camaro RS's Avatar
ive got the compucam 2032 with 1.6 roller rockers i ran a best of 13.3 @105.44 and run consitly 13.5@104.66 i love this cam ive got afr heads on the way and keeping this cam later
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
482-495 LIFT 214-220 duration full roller rockers
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
midly ported and polished stock heads
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit
new best ET 13.5 @104.66
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
