Plenum porting services available
Old Dec 30, 2000 | 10:23 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I'm enjoying my die grinder! I've been doing plenums since the fall, and each person that's received one has been happy with the work.
I've been on Thirdgen.org nearly since inception,and have several tech articles on the board. If you want me to do your plenum, visit my website for the details. Prices are cheap, overhead is low, and I can turn it around in about one week or less.
http://www.isthq.com/~dan/efi.html
references furnished upon request
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
Old Dec 30, 2000 | 10:58 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Dan did the work on my plenum and I was more than satisfied with his work.....top notch in my book...
wishmister@yahoo.com
1987 White IROC-Z
305 TPI LB9 273 Rear Gear
700-R4 auto tranny
97,000 miles
KYB's
Performance Resource Chip
Flowmaster Muffler
Ported/Polished Plenum by "Daniel Burk"
Holley AFPR
Throttle Body Coolant bypass
TPIS air Foil
TPIS MAT Relocation Kit
K&N's
Gutted air box
Accel 8.0 plug wires
Moroso Super Coil
Blue Streak Cap and Rotor
Boush Patinum +4's
Mobil 1 15/50 Synthetic motor oil
Mobil 1 synthetic Trans fluid.
My Car:http://albums.photopoint.com/j/ViewPhoto?u=1426474&a=10682240&p=36621420
Old Dec 31, 2000 | 07:31 AM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
Hey Dan, would you happen to do any head work as well? I got a set a L98 aluminum heads and I want to remove all those casting imperfections, on the intake and exhaust ports. If you don't would you know about how much I should look to spend on something like this? Thanks
Old Dec 31, 2000 | 01:52 PM
ws6transam's Avatar
As you may know, I ported my own cylinder heads for my 305 and chopped 1.5 seconds off the quarter mile time. my 305 is now nearly 101 MPH in the quarter mile with iron 305 heads.
Based on that experience, I'd say the cost for doing the bowl work & gasket match would be about $300. I put 25 hours into my iron heads, and your aluminum heads would probably go faster. I spend about $5 per hour on electricity, and about $5 per hour on grinding materials, carbide cutters, and wear on my grinders. Assuming I get the job done in 16 hours, that would put my labor at about $10 / hour.
I can't see doing the porting in any less time, if we wanted it done right. Email me for more details.
Cheers,
Dan
Daniel Burk
[This message has been edited by ws6transam (edited December 31, 2000).]
Old Dec 31, 2000 | 02:35 PM
Drewcifur's Avatar
Car: 1989 Firebird Formula
Engine: 350 ZZ3
Axle/Gears: Stock
Hey guys, I figured this is the best place to ask this question. I'm looking to buy a plenum and ship it to Dan to get ported. My question is, Will a 87 tpi plenum fit my 89? Is there any differences or are they the same? Thanks
89 Formula
Edelbrock Headers+
Catback system,Torque Converter,Rebuilt Trans,B&M Megashifter, K+N air filter, Accel Distr. Module, MSD coil,New Fuel injectors with adj. regulator, ECM with performance prom,and a Crate ZZ3 350
Old Dec 31, 2000 | 04:43 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
As far as I know the only difference in any tpi base is the intake bolt pattern on the 85-86 vs. 87-92. You shouldn't have any problem unless you get a 'vette base w/ no EGR provisions.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N
Old Jan 1, 2001 | 01:45 PM
rondubbs's Avatar
the 89 PLENUM will have a hole for the map sensor, the 87 dosent, just plug it.
Old Jan 1, 2001 | 08:48 PM
ws6transam's Avatar
I have a 1985-1988 casting and a 1989-up casting here, and the difference is in the very front of the plenum. The 1985-1988 casting has a triangular hole that is open to the throttle body, and connects to the cold-start injector circuit, I believe. The 1989-up plenum doesn't have this hole, and the floor of the plenum is not contoured to accomodate the passage. Other than that, they are similar.
Since this thread is getting non-technical in nature, and I'm feeling kind of self-concious about my shameless marketing tactics, I suppose I should ask that anything non-technical in nature (such as inquiries on pricing, delivery, etcetera) take place via email. I also have a little bulletin board on my hobbyist site, if you want to use it for this purpose.
Otherwise, if there are any technical questions on the porting details, those are probably still appropriate for this forum.
Here's my humble little third-gen TPI page, with some of the porting details. Browse up to the main fcar page, and over to the weekly project notes if you want to ask any buisness-oriented questions in a public forum.
http://www.isthq.com/~dan/efi.html http://www.isthq.com/~dan/fcar.html
Cheers,
Daniel Burk
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
Reid Fleming
Oct 10, 2015 09:56 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
