best injectors for my 383?? and can i make own fuel rails?
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
putting together a 383 HSR
ordered the HSR and i'll have it in 3 weeks
agh! also ordered 58mm TB from professional performance as well as there performace dampner.
got the hotcam/1.6rr/ double roller timing chain/new roller lifters
and my sexy *** 195cc aluminum patriot heads
im gona be running 30lbs injectors and i wanna kno wats the best brand to buy thats resonably priced
i heard accels are ok but ppl get bad batches and venoms are bad as well... i was thinking of ford SVO but i dont kno the part number or where to buy them?
also wat is this bull cr!p that i gotta buy 190$ fuel rails for the HSR and then buy an aftermarket fuel pressure regulator bc the holley adjustable one sucks!!!
is there anyway to modify the stock rails or maybe bend my own fuel lines connecting the stock fuel rails to fit around the HSR???? can it be done? i dont feel like paying 300$ for fuel rails/regulator....
agh! also ordered 58mm TB from professional performance as well as there performace dampner.got the hotcam/1.6rr/ double roller timing chain/new roller lifters
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Re: best injectors for my 383?? and can i make own fuel rails?
I see a lot of used LT1 rails cheap on ebay. A lot of guys have used them on other stuff. IMHO, probably your best choice.
Ron
Ron
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
LT1 rails have the injectors coming out at about a 5* angle, so they won't work. I'm pretty sure that the stock rails will work, just might have to do some fabrication on hooking them up to the fuel lines as where the stock ones run is occupied by aluminum.
Car: 87 TA clone
so stock tpi lines with a custom bend fuel line routing around the HSR could work???? idk why i would do it since id be saving like 180$ only lol...
got any other ideas wat i could do? and wat about my injectors?
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
30lb ford injectors, $239
http://www.fordracingparts.com/parts...tKeyField=1578
look up if theres any distributors around in your area
Car: 84' Monte
I'll see if I can get in touch with my buddies who have HSR's, one of them I know used the holley rails but I think the other guy used his stockers with AN lines instead of the stock hard lines.
I've had good luck getting used 30 lb'ers off of ebay for under 150$. I believe guys are getting them out of lightings as they are upgrading to 42's.
Car: 87 TA clone
are these ADS super
are these ADS super fuel injectors any good? ive never heard of them?
pm sent...
pm sent...
Last edited by customblackbird; Aug 5, 2007 at 03:24 PM. Reason: Automerged Doublepost
Ordered them from JEGs catalolg. Disc mass .5grams,disc type, non-clogging, very low restriction. Flow rate = 25 lbs per hour, part # 72398. In original packaging and never used. My brother installed them on his 1988 350 Formula Firebird with no problems. He had headers, prom, wires, coil, throttle body, etc. on his car. RICK
Car: 86 MCSS-87 Z28
Transmission: Auto OD-5spd
Axle/Gears: 3.73 both cars
