Shouls I just get a 58mm throttle body because it's nearly th same price as a 52mm?
Old Feb 8, 2001 | 02:37 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I'm about to order a new throttle body and was wondering if I should just buy a 58mm one instead of a 52mm one because they are only about $20 different in price. What do you think? I'm not sure if I'll ever need the 58 but it's only a little more. It wouldn't hurt performance any, would it?? Also, can the plennum be ported enough to match a 58?
Thanks for the time
Rob
1987 IROC-Z Auto (LB9)
Black/grey with the stance of a streetfighter
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat.
Future mods:
K&Ns
RAM Air
New Underdrive pulleys-either March performance pulleys or Auto Specialties Performance
Air foil
Old Feb 8, 2001 | 05:05 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Why spend all that on a TB when u could get other things that would give your car more HP?? The TB doesn't restrict as much as u think, especially for a 305. There are cars making more than 500HP with a 48mm TB, and they are 350's.
https://www.thirdgen.org/messgboard/...ML/001210.html
https://www.thirdgen.org/messgboard/...ML/001112.html
Looking For:
87 IROC-Z 350 TPI
84 TRANS AM 305 H.O.
[This message has been edited by IROCZTWENTYGR8 (edited February 08, 2001).]
Old Feb 8, 2001 | 11:26 AM
Guest
Guest
Posts: n/a
If you want to kill power, sure go get the 58.
I see from your sig you have an 87 with exhaust. An airfoil is probably your best bet, followed up by the 52 if you plan on porting and a cam in the near future. The 58 on a 305... well, a 305 that would need that you would not want to drive on the street.
Old Feb 8, 2001 | 11:57 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
a 58mm TB will kill your air flow velocity. your cylinders will not fill up as well as they could and you will lose power even a 52 is too big for a stock intake 305 IMO
Old Feb 8, 2001 | 12:37 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I agree with the others, you are not anywhere near needing a TB yet, you would be better served to spend your money elsewhere.
And i'd love to hear an explanation from 88 on how a 58mm TB will hurt velocity and torque.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Feb 8, 2001 | 12:40 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
He's right the 58 mm will hurt him. 58mm tb's are for cars in the low 12's high 11's. 52 is fine for mid high 12's-high 13's. other than that the stock is fine.
SUPERCHARGED 87 GTA: Blk/Gld w/Superam, 355cid Trickflows, forged pistons 9.5:1. Auto 2,600 stall, 3.45 9 bolt disc, Best time & mph (Naturally Aspirated): 13.567 @ 101.900 w/ a poor 60ft. Best mph: 104.3 *This car is 100% NYS emissions legal, w/ all emissions controls!* "If you want to have a fast car, hang out w/ those who do!"
http:// www.community.webtv.net/munks87/JustinsGTApage.com
VORTECH S-TRIM, INSTALLATION IN PROGRESS: 10 & 15 LB> PULLEYS, CUSTOM HKS RACE BYPASS, CUSTOM DUCTING W/ COLD AIR, SWAPPING TO SERPENTINE, & MANY EXTRAS! BEST TIME: 11'S I GUESS. WE'LL SEE IN SPRING!
Old Feb 8, 2001 | 04:05 PM
JAY87GTA's Avatar
To make you feel better, GM has a 48mm t-body on the ramjet 502 that makes 500+ horsepower. I'd spend that 300 bucks on something else!
'87GTA w/ SLP Cold Air, MSD Coil, Airfoil, Gutted MAF, AFPR, TES Headers, HI-FLOW CAT, Flowmaster Catback, Energy Suspension Master Bushing Kit
Old Feb 8, 2001 | 06:27 PM
Administrator
Your car would get better results just by porting the plenum, airfoil, and airbox mods.
Looking For:
87 IROC-Z 350 TPI
Old Feb 9, 2001 | 01:52 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
I'm waiting for my AFPR, K&Ns and my RAM AIR to come through. I'll be porting the plennum and gasket matching everything too. As I'm getting a cam change in the summer I figured it would be better to get a 52mm throttle body than just the air foil.
Old Feb 9, 2001 | 05:57 AM
Administrator
No, just get the airfoil, its a 305 not a 383. U could spend that money on things that would actually make your car faster.
Looking For:
87 IROC-Z 350 TPI
[This message has been edited by IROCZTWENTYGR8 (edited February 09, 2001).]
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
