what is faster in our third gens?
Old Sep 11, 2007 | 10:08 AM
hung4wheeler's Avatar
Car: 87z28
Engine: 70 LT1
Transmission: 350 TURBO BUILT BY B&M
Axle/Gears: 12 BOLT POSI
is a 350 stock carbed motor faster than our tpi motor stock
just asking ive been thinking about going to carb for a while
I really just want to put a whole differant motor in but just wondering what my car would run in the 1/4 mile with a mildly built 350 or 327
Old Sep 11, 2007 | 10:56 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: what is faster in our third gens?
Originally Posted by hung4wheeler
is a 350 stock carbed motor faster than our tpi motor stock just asking ive been thinking about going to carb for a while
I really just want to put a whole differant motor in but just wondering what my car would run in the 1/4 mile with a mildly built 350 or 327...
There are honestly way too many variables, as well as what your definition of mildly built literally means....
Old Sep 11, 2007 | 11:00 AM
Car: 87z28
Engine: 70 LT1
when I say mildly built i mean a mid sized cam shaft 'headers and carb upgrade '''which one is faster in our thirdgens 350 carb motor or tpi motor
Old Sep 11, 2007 | 11:12 AM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
tpi limits hp above say 4500 on a 350. figure out some combos and then ask the question again. as stated way to many variables.
Old Sep 11, 2007 | 12:09 PM
Car: 87z28
Engine: 70 LT1
ok maybe this is better ok
take a stock 350 tpi motor with older style heads my bolts dont go thrue the middle of the valve covers
take a stock 350 carb motor that red lines at 5500
and which one of these motors would make my 1986 z28 the fastest
Old Sep 11, 2007 | 01:12 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
What are the specs on the "older style heads"? Just because they are a different bolt pattern doesn't mean they are better than the factory heads.
I think what Street Lethal is saying is true... there are alot of specs that determine how "fast" a car will be. So, saying a "stock 350 carb motor" is pretty generic. For example, a 350 carb motor that came stock in a 1969 Camaro may be 350HP, whereas a 350 carb motor that came stock from a 1977 Camaro may be 250HP. As you can see from this example, both motors are "stock 350 carb" but they are quite different.
No one is trying to be difficult or hassle you... its just a tough question to answer without all the necessary specs.
Hope this helps.
Old Sep 11, 2007 | 01:29 PM
Car: 87z28
Engine: 70 LT1
ok I got you here you go take a stock 1986 chevy 350 motor that is carb or a 1986 350 tpi motor which one would be the faster motor for my car what I meant bye older style heads is my tpi motor has heads that are factory but the bolts go around the ouside instead of in the middle some body on here told me they wer older style heads thats all I was saying
Old Sep 11, 2007 | 03:01 PM
I'm sure its debatable, but my 2 cents is the TPI motor would be faster off the line and probably in the 1/4. However when you get into higher-rpm's, as rjt76 mentioned, the carb would be faster due to the air limitations of the factory TPI. It really just depends on where you want the powerband.
FYI - I'm assuming we are using the same car when comparing motors (that way we have the same vehicle weight, trans, rear gears, etc).
Hope this helps.
Last edited by formula_novice; Sep 11, 2007 at 03:03 PM. Reason: Automerged Doublepost
Old Sep 11, 2007 | 03:38 PM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
I think with the same bottom end, heads, cam, and iginition, with a Qjet carb/stock GM intake vs. TPI (thats as stock for stock as you can get), the carbed motor should make more power, especially on the topend. The TPI may make better lowend, but by 3000rpm the carbed motor would be pulling strongly, and pull well beyond TPI's topend limits. But, TPI can be made to run well, has great throttle response (compared to a stock Qjet) and is much better for a daily driver.
Old Sep 11, 2007 | 09:33 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
In case you didn't know, there wasn't a stock 350 carbed thirdgen camaro/firebird.
But, if it's a daily driver, and not too modified, and already has a good working TPI, I'd spend the money on the TPI.
If it's mostly a toy that you don't care that you have to pump the throttle to start, hold it open to idle cold, or run with a choke, and have bad mileage, and want to spend money on an intake, carb & air filter, distributor, pump or regulator, lines, etc.. but want a better E.T. then a good* carb setup is usually faster with less skills.
Old Sep 11, 2007 | 11:44 PM
Car: 87z28
Engine: 70 LT1
I already have a tpi motor in my car I just wanted to see if I went to carb
if my car would be faster that is all
Old Sep 12, 2007 | 01:00 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Honestly its a matter of who you ask. Ask a carb guy, and he'll tell you a carb is faster. Ask a TPI guy, and he'll tell you the TPI is better. In reality, a carb is better for a race car, and a fuel injection setup like TPI is better for a daily driver.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
toones
Jan 6, 2016 06:00 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
Americanmouse
Sep 7, 2015 12:10 PM
luvofjah
Aftermarket Vendor Review
Aug 31, 2015 11:22 AM
