RAM JET: Has anyone successfully done this swap?
Old Mar 12, 2001 | 08:44 PM
89ROC's Avatar
I see that this manifold only costs $400. Sure beats the Miniram and Superram on price. I know I've heard of people wanting to do this... So, like the title says, has anyone actually done this yet? If so, what were the results? What all did it take to do it?
Thnx
89' Iroc-Z
ZZ3 short block-355 TPI ZZ9 cam
NOS 150 shot.
blah...blah...blah..
95' T-56, 6-speed
99' Z' rearend w/ 4.10's
1997 black Trans AM
LT1, A4, basically stock.
[This message has been edited by 89ROC (edited March 12, 2001).]
Old Mar 12, 2001 | 09:13 PM
Joseph@SDSC's Avatar
Here is a few scans I took from the service manual of the wiring diagrams and part numbers. They are big pictures so that someone could print them if they wanted. http://67camaross.cz28.com/RJ350/RJ350.html
I plan on doing the swap someday...going with the RJ CPU and wiring harness on mine and using SVO Injectors. The fuel rails aren't available yet from GM, but you could have them made from Fuel rail stock available from Arizona Speed and Marine. The TB is an LS1 design.
I know of 1 person that is going to use an Accel DFI system on a RJ system. I am using the RJ CPU and harness because I have access to having the CPU reflashed for my engine.
-Joseph
ASE Master Automobile Technician
Scoggin-Dickey Chevrolet
1967 Camaro (Vortec Heads, GM ZZ4 intake manifold, ZZ4 roller camshaft)
1992 Firebird (Weiler Vortec Heads, LT4 Hot Cam, GM ZZ4 Intake, Edelbrock 750, eventually will be Ram-Jet)
Old Mar 12, 2001 | 09:19 PM
Steve R's Avatar
What exactly does the $400 get you?
1980 Camaro, '88 Police 350 engine, Headers, full exhaust, completely redone, my baby!
1988 Iroc-Z L98, MSD 6a, Accel coil, K+N's, Airfoil, Coolant Bypass, Flowmaster, Gears, Late model Bose, I like the 80 better
Old Mar 13, 2001 | 09:01 AM
FormulaJoe's Avatar
Im working on it right now. Only im using GMPP fast burn heads and LT4 hot cam. I am getting the Ram Jet computer reprogrammed by AS&M to make it all work. Other than that, Im using the Ram Jet injectors, throttle body, wiring, etc.
L98, 3.27 9-bolt, Hooker shorty headers, custom 2.5inch Y-pipe, no cat, 3inch 2chamber flowmaster, JET AFPR, Ported MAF, Best ET: 13.86 @100mph. 1.99 60'
17 inch ROH "ZS" wheels. 17x8.5(front) and 17x9.5 (rear). Firestone Firehawk SZ50s. 245/45/zr17s and 275/40/zr17s. T56
On the way... Radar Blue 89 Formula, T56, Ram Jet 430, Ram Air, 17inch ROHs.
Old Mar 13, 2001 | 06:43 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Does the ramjet clear the stock 3rd gen hood or do i have to get a cowl? I want to get the crate $4500 for 350hp and 400lbs/ft sounds up my alley, but I want to get it painted again before the swap. No sense painting the hood if I can't use it and end up painting another hood.
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
Old Mar 13, 2001 | 09:44 PM
GhoSSt's Avatar
Yes, Street & Performance is running RJ's off of 7730 in their current catalogs, it will fit under the stock hood, 400.00 gets you a bare RJ intake. Any other questions?
Kelly 'GhoSSt' Rosato
1996 Impala SS, 383 LT4 (14.65 up here, 13.24 lower)
1984 Firebird, +.060 350 (Vortech Heads, HOT Cam, and schtuff)
1993 Caprice, 5.7 TBI (stock . . . FOR NOW)
"And if you wrong us, shall we not revenge? Revenge. The villany you
teach me, I will execute, and it shall go hard but I will better the
instruction."
Shylock in Act III, Scene I of 'Merchant of Venice' by William Shakespeare
Old Mar 13, 2001 | 11:32 PM
RyanSS's Avatar
Where do you get a ram jet system at? is it better than TPIS mini-ram II? What is the cost? I am looking for a good system for the 400sbc going in my 89 RS.
Old Mar 14, 2001 | 02:11 AM
GhoSSt's Avatar
<font face="Verdana, Arial" size="2">Originally posted by RyanSS:
Where do you get a ram jet system at? is it better than TPIS mini-ram II? What is the cost? I am looking for a good system for the 400sbc going in my 89 RS.</font>
You don't want a RJ in that case. It only works with Vortech or Fastburn heads and neither are suitable for a built 400. Go MiniRam if its a stick, SuperRam if its an auto.
[This message has been edited by GhoSSt (edited March 16, 2001).]
Old Mar 14, 2001 | 07:20 PM
JoelOl75's Avatar
Thanx! I have the dementions for the maifold, but thats based on height off a 8 cylinder block. I'm ditching the six. Have a tranny almost ready for it and it already has a 9 bolt in it (although the posi doesn't lock). I figure a walbro 255 and some junkyard pulleys and brackets, I could bring her back to life (I was considering selling for a 95 six cylinder)
Now I could have 2 gas pigs!!!!
What kind of MPG can I expect from the crate with 700r4 and 3.27's
I have a 700r4 and 4.10's in the bird and get 15-18 MPG. It should be in the 20's, but is it like the LS1's (near 30's)??
9192camaro
16
Feb 3, 2019 12:21 AM
ZZ42Fast
Aug 30, 2015 02:39 PM
L98GTA87
Aug 11, 2015 06:55 PM
bryan623
Aug 10, 2015 11:33 AM
