What AFR heads for 11-12 sec. 350 TPI, 190cc, 195cc, 210cc or what??
Old Mar 24, 2001 | 03:25 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I'm trying to decide my mods will be for the IROC 350 TPI once I get it, which I will be wanting to get in the 11's-12's, and I will have to get heads for those kind of times, so what cc should I get?? Cam and base recommendations are cool too. Thanks!!
Looking For:
87 IROC-Z28 350 TPI: The car I want.
84 TRANS AM 305 H.O.: Another car that would be OK to own while I look for the IROC-Z!!
[This message has been edited by IROCZTWENTYGR8 (edited March 24, 2001).]
Old Mar 24, 2001 | 10:20 AM
bad camaro RS's Avatar
ive got AFR 195cc heads and theyre awesome i was running 13.5-13.5 in 1/4 with stock heads i feel as though ill be mid 12,s after afr swap its a totally different car and this is my daily driver later
1992 camaro RS
195cc AFR heads with compition port work milled to 58cc "10-1 compression"
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.65 full roller rockers
497-510 LIFT 214-220 duration
msd6AL
1 3/4 hooker long tube headers
4" mufflex system
k&n filters gutter air box gutted maf"no fins no screens"
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
taylor 8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit edelbrock water pump
new best ET 13.5 @104.66
no times with new afr heads hoping for 12's on motor
Nos installed but no times yet
about:blankhttp://www.nav.to/badass355tpi
Old Mar 24, 2001 | 05:04 PM
Dan87IROC-Z's Avatar
If you are gunning for the 11s, and are going to use just a 350, not a larger motor, I would go with the 195s. That way, you can use either a Mini Ram or a modded TPI set up. I would go with a large cam with those heads, the LT4 HOT Cam I am running I think would work well. You could also look at the line up of cams from companies like Comp Cams or Crane Cams, or also the Big SLP Cam would probably work well.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old Mar 25, 2001 | 08:12 AM
Administrator
So I should go with the 195's right?? The air intake is going to be a modified TPI. LTR's, ported plenum, modded airbox, maybe a SU145 MAF, maybe a 52mm TB, and other stuff, not too sure about what cam and intake base yet. I want to keep that really good lower RPM TQ of the TPI with some good HP too.
Looking For:
87 IROC-Z28 350 TPI
The car I want.
Another car that would be OK to own while I still look for the IROC-Z!!
[This message has been edited by IROCZTWENTYGR8 (edited March 25, 2001).]
Old Mar 25, 2001 | 02:39 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
I am going to a setup similar to yours. I am getting the 195's with a edelbrock base(ported like TPiS bigmouth) and crane cam with 495'' 503'' on a 112 (like Traxions cam)center lobe. Seemsd like everything is going to work well
Old Mar 25, 2001 | 03:23 PM
MikeC.86Roc's Avatar
Somebody please explain to me how to fit the AFR 195cc heads onto a stock or similar to stock (eg. edelbrock, accel e.t.c.) intake manifold. I have a set of AFR 190 heads and when I ordered them direct from AFR the salesman warned me that the 195s will not work because of the height of the intake runners on the intake base not matching to the heads. Tell me that this guy was wrong so I can call back to AFR and bitch.. Or have all you guys been "hogging" the runners on the bases to match the runners on the heads? In which case, you should make this guy aware that if he buys the 195's he better be ready to port match his base to the heads.
Old Mar 25, 2001 | 07:39 PM
Administrator
86, when I do the heads, I'm going to do the base and cam also.
Looking For:
87 IROC-Z28 350 TPI
The car I want.
Old Mar 25, 2001 | 10:17 PM
nope i didnt hog anything it all bolted together perfect direct bolt on later
1992 camaro RS w/ 350tpi
4" mufflex system
eddelbroc intake base and runners and much more
new best ET 13.5 @104.66 on stock heads
Old Mar 27, 2001 | 12:37 AM
Anniversary-SS-man's Avatar
Hey Dan87, if you were to use the SLP cam in the above setup, were you referring to the 51006 or the 51010? Thanks.
1997 30th Anniversary SS LT4 #74 with K&N, white gage faces, and Hotchkis shock tower brace - SLP SBC's on the way
1996 Corvette Grand Sport LT4 #509 with K&N, Flowmaster exhaust, Hypertech power programmer, and Baer slotted/cross-drilled brakes - on the way: SLP throttle body and 1-3/4" headers, heads ported, 4.10 gears, custom Panasonic/Alpine/Audio Control audio system
2000 Chevy TrailBlazer
evilstuie
Jan 9, 2020 08:29 PM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
89mulletbird
Aug 12, 2015 07:08 PM
