Identify this TPI please...
Old Mar 27, 2001 | 08:52 PM
GndPrx's Avatar
Ok, I know I've asked this before and someone came up with the answer I needed, but the original post seems to be wiped out of the archives...so here goes again.
I am about to put this up for sale on ebay and was hoping someone could identify it for me and tell me what all parts it appears to have or even what is missing from the basic setup other than wire harness and computer which I do not have.
I know the manifold, throtle body, runners, rails, injectors and distributer cover. What is missing from this list that is in the picture? (As you can tell I'm not a big TPI person which is why this is getting sold)
Thanks in advance.
Carl
[This message has been edited by GndPrx (edited March 27, 2001).]
Old Mar 27, 2001 | 09:31 PM
evilho7810's Avatar
It looks like an 89 maf tpi.
Old Mar 27, 2001 | 09:50 PM
CamaroX84's Avatar
I can't really tell from the picture, but is there a fuel pressure regulator mounted on there? I can kind of make if out there in the back but I can't really see too well. I would make sure you have one on there if you are selling it. Just my two cents.
Old Mar 27, 2001 | 10:39 PM
superz's Avatar
where is the MAF??
the TPS looks kinda jacked too
Old Mar 27, 2001 | 10:50 PM
Guest
Guest
Posts: n/a
Its 89.
The FPR is there, just not the color you think it should be
Old Mar 28, 2001 | 01:33 AM
Omar's Avatar
It's an 85-88 plenum, mounted to a pair of 89 runners. But you would definitely sell it as an 89 MAF TPI.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Mar 28, 2001 | 06:36 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
Is that a high flow cat there also??
Old Mar 28, 2001 | 07:11 AM
GndPrx's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Kevin Irving:
Is that a high flow cat there also?? </font>
HAHAHAHA
Thanks for the help so far all. I picked this piece up a while back in hopes of doing a conversion, but decided against it.
I'll just put that it's about 90% complete '89 MAF TPI unit, unknown working condition. Anyone see any issues with phrasing it like that for a description?
Thanks,
Carl
Old Mar 28, 2001 | 07:54 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
I would label it as less MAF, wiring and computer.
Old Mar 28, 2001 | 01:06 PM
GeeTA's Avatar
....looks like the MAF might be there...inside the plastic bag....who knows.
-TA
'82 TA "FRANKENBIRD" - built with various F-Body parts from '82 to '96.
CURRENT: '91 305, '96 T-56 6 speed, 3.42 POSI, '89 WS6, '86 TPI, SLP 1 3/4" headers
SOON: 350, Trick Flow TW heads, GM-HOT cam kit, PBR disc
Old Mar 28, 2001 | 01:57 PM
irocbob89's Avatar
looks like 91-92 intake to me.
89 red iroc-z
386 strocker
ross pistons 10.5.1
eagle h-beam rods
miniram
slp cam 224 230 535 544
1.6rr
edelbrock performers p+p
ford 9', 4.11, 31 spline
baer rear brakes
line lock
all the bolt ons
200 shot on the way
Old Mar 28, 2001 | 03:54 PM
superz's Avatar
well irocbob it sure ain't no 90-92 cuz the flexible ducting for the maf is there. how can u guys tell the difference between 85-89 runners? the runners look kinda beat to hell anyway.
[This message has been edited by superz (edited March 28, 2001).]
Old Mar 28, 2001 | 05:51 PM
Car: 1985 Trans Am
The 85-88 runners have a hole in the bottom flange on the driver's side for the cold start injector, that's the difference along with the smaller tube in between the runners is gone.
Old Mar 29, 2001 | 12:16 AM
superz's Avatar
why is that small tube not there? i thought that was part of the EGR? pardon my ignorance, i just haven't been exposed to tpi motors other than my own.
Old Mar 29, 2001 | 11:44 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
The small tube is used for EGR on MAF units. Speed density does not use the egr, so the small tube on the drivers side was removed. Either will work on either setup. You just have to blank off the 9th injector hole on speed density units.
Old Mar 30, 2001 | 04:10 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Yes SD does use an EGR, but it is definitely not an SD unit. You can tell by looking at the rear passenger side of the plenum: SD units have the MAP sensor there...this unit does not have the MAP sensor or a tapped hole to bolt it in.
Old Mar 30, 2001 | 12:57 PM
Synergy's Avatar
I think those are Corvette runners because it doesnt have any small tubes at all on either side. My car, a 92 Z, had a small tube on the driver side which EGR does go trough. Since the vette uses a completely different EGR system I believe those are vette runners. Who knows...take a closer look at where the fuel fittings are and if they bend towards the passanger side then that's a corvette TPI.
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car.
Check out our car club Truspeed
Check out the Bin Archive for all your .bin needs
Old Mar 30, 2001 | 01:36 PM
GndPrx's Avatar
Thanks for the input from everyone so far. Just to clarify since you can't see in either of these pictures, there are smaller tubes running almost behind and off to the side slightly the 2nd runner on each side.
Current bid on ebay is up to $300 on this piece, hell I only had a reserve price of $100. I'm supprised it's so high.
Thanks again all.
Carl
Old Mar 30, 2001 | 11:05 PM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
so thats where my intake went!
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Redwhisper
Aug 26, 2015 05:02 PM
Linson
Aug 21, 2015 02:12 PM
Street Lethal
Aug 14, 2015 08:25 PM
Sanjay
Aug 12, 2015 03:41 PM
