did it come with 305 TPI or 350 TPI?
Old Apr 1, 2001 | 09:37 AM
STL1994's Avatar
well, i want to buy a 91 or 92 formula firebird. but, which motors came stock in those cars, 305 TPI, 350 TPI, or both?? what transmission options did they come with?
thanx
(let me know if this is the wrong board to post this in, i couldnt find any other.)
Old Apr 1, 2001 | 10:32 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Could also be the 305 TBI. Just look at the eighth character if the VIN number.
"E" is the 305 TBI
"F" is the 305 TPI
"8" is the 350 TPI
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Apr 1, 2001 | 12:04 PM
STL1994's Avatar
whoa, i didnt know Formulas came with TBIs, so i geuss i am in the wrong board. anyway, a friend of mine told me a second ago that the 305s came with manuals and autos, and the 350 came with only auto trans. is that true?
thankx
Old Apr 1, 2001 | 01:25 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yes, the 305 TPI could be had w/ a manual.
Some say that a few 350's came w/ the manual, but nobody really had been able to prove it, and even if its true, the numbers would be so few, you probably wouldn't come across one.
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Old Apr 2, 2001 | 07:27 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
That is, unless it was a TPI from '85 or '86, then it came with an auto... no manual TPI's until '87 from the factory.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
