58mm Throttle Body VS 52mm, Trade?
Old Oct 14, 2007 | 09:28 PM
drb930's Avatar
Car: 1987 Chevy El Camino
Engine: 357 CID w/Lingerfelter Super Ram
Transmission: 700-R4
Axle/Gears: GN 8.5 342's
I have a 58mm throttle body, is this going to be too big for a 357?
Anyone out there have a 52mm that they want to trade?
Dave
drb930@netzero.net
Old Oct 14, 2007 | 09:42 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: 58mm Throttle Body VS 52mm, Trade?
"I have a 58mm throttle body, is this going to be too big for a 357?"
The answer is maybe. If you don't open up the plenum to match the 58mm than yes it is too big. From a technical standpoint the answer is no. I run the 58mm myself.
Old Oct 15, 2007 | 06:07 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
if all the porting has been done and your running 450-500+ hp then the 58mm would be better. 58mm just flows more air which would mean that our motor would have to be a rever or u will lose low end hp/tq bc the velocities would be lower... like 5500-6000rpms or more peak hp
Old Oct 15, 2007 | 06:26 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Dave
drb930@netzero.net
On a stock car its over kill. What else has been done besides the 7 extRA cubes?
Old Oct 15, 2007 | 10:08 PM
drb930's Avatar
Sorry forgot the details-
357, 4-bolt mains, 010 block
Forged "Pink" rods and Lunati forged crank
Windage tray and baffled oil pan
TRW forged pistons 10.5 to 1
AFR 195 Street Elim 64cc heads
LPE 219/219 560/560 cam
LPE intake, 30 lb injectors
Block converted to full roller using V-6 lifters
Doug Thorley Tri-Y headers.
Dave
Old Oct 24, 2007 | 09:00 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
There is no reason to run a 58mm throttle body on a car running 450 horse. The 52mm works great until around 600 horse. You don't need the 58mm (1100) cfm which is overkill unless your making serious horsepower. The equation for that would be for every horsepower that you make you need 1.5 cfm of air for it.
Old Oct 24, 2007 | 09:15 AM
drb930's Avatar
That's what i think also, i going to try to trade it out for a 750 CFM 52mm.
If anybody knows someone that wants to trade, please let me know.
Thanks,
Dave
Old Oct 24, 2007 | 11:59 AM
Car: 1989 GTA
Engine: 369 TPI
You should get a ton of offers.
Old Aug 22, 2008 | 09:11 AM
drb930's Avatar
Bump-
Still looking for someone that wants to trade their 52mm for a nice 58mm.
Dave
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Thornburg
Aug 27, 2015 08:33 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
