LT4 Hot Cam for what price?
Old Apr 9, 2001 | 09:27 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
I would like to get the LT4 Hot Cam (of course i have other mods in line) but...my real question here is...who has the cheapest price? Kits? What MUST i replace when i do this? Experiences? Driving around town? This isn't my daily driver anymore so i figured this summer i'd start modding some more. I am still decideing on headers, etc...btw, i searched for this kinda topic but nothing? i know for sure i have seen some topics on this.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
[This message has been edited by branz28 (edited April 09, 2001).]
Old Apr 10, 2001 | 09:18 AM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
ttt
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
-Gutted cat
-!AIR
Old Apr 10, 2001 | 09:48 AM
Beefy89's Avatar
LT4 Hot cam,part #24502586 $167.66 at www.gmpartsdirect.com
Fast as a shark~~~~~~~~~~~~~~~~~ SAVE NAPSTER!!!
Old Apr 13, 2001 | 10:48 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
If you know someone that works at a GM dealer (has a discount), you should be able to get it a bit cheaper than that price is after the shipping and handling.
Old Apr 14, 2001 | 10:05 AM
Beefy89's Avatar
Theres one in the classifieds right now for $125.
Old Apr 14, 2001 | 10:50 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Too late.
Old Apr 16, 2001 | 05:17 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
that cam is too big for a stock motor spend your money on the intake first you'll see better numbers with the stock cam and modded intake than you would with a stock intake and modded cam
Old Apr 16, 2001 | 08:33 PM
Dan87IROC-Z's Avatar
I have the LT4 HOT Cam in my 87 IROC 350 and I do have to say that is does need more intake to take advantage of it, and definetly lower gearing than I have now. If you have a 3.42 or 3.73 rear end and some intake mods then you will be very happy with the cam, if not, you will need to do those otherwise it will slow your car down. You will absolutly have the change the valve springs and the timing chain with it. I do know that when I install my new rear end and new intake, the car is going to rock!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
theurge
Aug 21, 2015 12:46 PM
80s Poncho
Aug 19, 2015 06:45 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
