Trick Flows: Which is better, 23* or Twisted Wedge?
Old Apr 17, 2001 | 11:27 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I am thinking about going with a new set of heads with my current engine build and the prices on the TFS heads are pretty good (especially with the discount ). Which heads work better on TPI's, the Twisted Wedge or the 23* ones? The engine will have the Edelbrock TES, ported and matched plenum and intake with SLP runners, and the LT4 Hot Cam.
Matt
1987 GTA L98 4L60 BW Rear w/3.27
(engine in progress)
Old Apr 18, 2001 | 04:20 PM
Matt87GTA's Avatar
Anybody????????? I gotta know which one is better so i can order them before the discount goes away (April 20)
Old Apr 18, 2001 | 05:18 PM
superiroc's Avatar
Go with the wedge, I have the old wedge heads for 3 years know on my super rammed 350 and have gone 12.7@111 my car is not setup for drag. They realy work well
Old Apr 18, 2001 | 07:17 PM
87iroczmd's Avatar
hey superiroc, how do you like the super ram i was thinking about getting one
Old Apr 18, 2001 | 09:01 PM
superiroc's Avatar
its great it makes alot of hp and tq. Its a pain to put on but its worth it. I don't know if you saw the recent post on the sr vs the mr the sr seems to realy work well.
Old Apr 18, 2001 | 11:16 PM
raging86's Avatar
can you pull the valve covers with the super ram still on? or is it like those crappy 5.0 mustangs that you have to pull the upper intake to remove the valve covers?
86 IROCZ
T-Tops
700R4
305 TPI
3.23 gears
shift kit, manual TC switch, manual fan switch, flowmaster exhaust with edelbrock TES headers& hollow cat, gutted MAF.
Old Apr 19, 2001 | 12:58 AM
superiroc's Avatar
yes you can pull the valve covers with the sr on.
Old Apr 19, 2001 | 01:08 AM
Greenshamrock77's Avatar
THE 23 DEG!!!!!!!. Twisted wedge are crap. They warp, crack, and have hoprrible Valve geometry. I bought a set of 23 deg heads...beutiful pieces. Plus I got the word from the man of SB chevys himself-Ed Taylor. His shop is next to mine. He dynos these things all the time and highly recomends them. He tested the 23 deg vs AFR heads and the TFS made only 3(three) less HP! They are also reliable and $850 from summit. Can't be beat!
Old Apr 19, 2001 | 01:52 AM
Matt87GTA's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Greenshamrock77:
I bought a set of 23 deg heads...beutiful pieces. </font>
I am leaning toward the 23* heads as of now. I see a lot of people running these. What is your setup and what kind of power/performance did you get with them? Are they the plain 23* or the CNC-profile chambered ones?
Old Apr 19, 2001 | 08:11 AM
jimbo's Avatar
Car: 1991 Formula Firehawk (Clone)
Engine: 350 with Firehawk Package
...I've run both on my car...had the TW heads on for about 7 years and just switched to the CNC 23 degree heads. If you use the TW centerbolt heads, you have to gut your valve covers to clear the rockers, and you're severely limited on aftermarket rocker selections. With the 23 degree heads the Crane Gold 1.6 rr's clear the stock valve covers fine. Can't really vouch for the performance difference between the two because when I replaced the heads I also replaced the cam and rockers and did some port matching, but having put up with the oil leaks caused by the TW heads and the valve cover hassles, I would definitely recommend going with the CNC 23 degree heads if you have a choice...
jimbo
Mosquito Coast F-Body Association (MCFBA)
1991 Formula SLP350
1999 Trans Am Firehawk
Old Apr 19, 2001 | 01:37 PM
superiroc's Avatar
Has anyone got any 1/4 times with the 23* heads? I havn't had any problems with mine. I think the problem is people using the incorect lengh push rods with the tfw heads.
Old Apr 19, 2001 | 03:35 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Well I just built up my engine and Ill let you know how my 23* heads and Mini-Ram work together. The motor is built up on the stand and she's going in on Sat. I cant Wait!!
Convertible, L98, Mini-ram, ZZ9 cam, Comp Cams 1.6/1.52 steel roller rockers, Trick Flow 23* heads, K&N's with chopped airboxes, March underdive pulleys, Edelbrock ceramic coated TES, Flowmaster cat-back exhaust, Dynomax high flow converter, MAC subframe connectors, Accel box & coil, Fastchips custom chip, 3.23 rear gears, white face gagues, and NOS!
Old Apr 19, 2001 | 03:56 PM
Kevin G's Avatar
I think the 23 degree heads flow like 20 cfm @28 inches more on the intake side also. Someone also mentioned that you need to hack the valve covers on the twisted wedge heads.
My TFS twisted wedge heads flowed 230 cfm@ .550 lift on thew intake side
I think people are flowing 250 cfm out of the newer 23 degree heads.
Old Apr 19, 2001 | 05:42 PM
FAST LiFE's Avatar
I'm using the TFS 23* and have no complaints about them. Have gone 11's NA with those heads fully ported. You can use standard valve train components without any problems. From what I hear, alot more consideration to valve train components is needed with the TW's and also a limitation with valve lift before having the re-cut the piston notches. Correct me if I'm wrong, but don't the TW's use cheaper cast valve guides? If that is the case, not a very good idea on aluminum heads. Should be using bronze guides like the 23*.
N/A 406, TPIS Miniram, 58mm TB, 30lbs injectors, Custom Ground Elgin Cam, Ported TFS heads, SLP 1-3/4", & DFI computer.
11.70@117mph
Old Apr 20, 2001 | 02:12 AM
Matt87GTA's Avatar
I just ordered the 23* TFS heads. I'll slap a post up here and let ya'll know what I think in a few weeks (hopefully) when the car is done. Thanks...........
Matt
1987 GTA L98 MD8 GW6
"Stop Lights timed for 35Mph are also timed for 70Mph"
Old Apr 20, 2001 | 02:40 AM
Motor is not built yet. It is a FT 355 with accel SR intake, DFI, LT4 HOT CAM, 1.6 Comp magnum R/A. Given that the this is all the same as the ZZ430 motor from GM (except for the heads, fast burn vs TFS 23), which makes 430 HP, I am hoping for 430-450 GROSS HP; since the TFS flow better than the Fast burns. It is going in a high tech 46' chevy pickup, with a 700R4, that weighs 3000lbs.....EEEEE-HAW. That will be one wild ride...and a tire burner.
82' Z-28. 327" w/ flat tops. 216/228/112LS. Pocket ported 041 heads 1.94/1.50 SS valves. World Class T-5 from a 91'. Best run? Runs with 2001 vette to 150mph!
Hotrodboba400
Dec 10, 2019 07:07 PM
aaron7
Sep 30, 2015 09:15 AM
RS Reaper
Sep 27, 2015 07:04 PM
Abubaca
Car Audio
Sep 24, 2015 02:33 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
